Old 01-18-2010, 05:12 PM
ASTRO_AL is on a distinguished road
Cold Saw Roller Bench & DRO
Hi guys, I need to build a saw bench for my Pedrazzoli cold saw, and I want to incorporate a DRO for the fence so I can move it, lock it off and make cuts quickly and accurately (to the nearest mm or half mm is fine).
It needs a max length of 6 metre, and I have a 10" x 10" x 8 metre I-beam sat outside my shop waiting for a home...
I figure on mounting the beam on some legs bolted to the concrete, in this orientation: I-I (sideways). I'll mount some rollers into the top 'gulley'.
I could use some inputs on how to make the carriage for the saw fence / material stop. I'm doing this on a budget, so no high end linear bearings etc. Can I use angle iron & rollers or similar to give me enough accuracy?
The current plan is a pneumatic cylinder operating a mechanical brake which locks the carriage to the beam when in use. So I just press a button on the handle and slide to the next required position, it'll lock in place when I take my thumb off the button. I'm not sure yet if the locking process will shift the carriage slightly.
Any ideas on the DRO would also be appreciated. I figure on a rotary encoder with a counter calibrated to give a reading in cm & m. What have others used over a length like this? It seems most other encoders are out on cost grounds (due to the range of motion)? Has anyone seen a decent homebuild DRO / counter in a similar application?
Thanks for any ideas.
Old 01-19-2010, 09:16 AM
rowbare is on a distinguished road
Check out what this guy is doing:
About 3 minutes in, he describes his cut-to-length system. Decidedly low tech but accurate to ~.1 mm (.005")... It looks like a bit of work to set up but it is rugged and all but foolproof.
bob
Old 01-19-2010, 11:10 AM
Thanks, in fact it was that very video that started me thinking about how to sort mine out!
I decided I'd prefer a rolling stop, although I like his system. I think bolting down plates is pretty slow for a quick-set end stop, I also think on a Friday afternoon I'd be prone to putting the right plate on the wrong set of holes...
Cheers, Al.
Old 01-19-2010, 11:18 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
that guy can pound brew
Looking for cold air gun boomerize Want To Buy...Need help! 1 08-09-2009 09:07 PM
Cold air gun bilinghm Benchtop Machines 4 07-25-2008 03:52 PM
cold gun fourperf Fadal 4 11-14-2007 12:28 PM
How cold is to cold for BP Series I CNC jho5820705 Bridgeport and Hardinge Mills 15 12-20-2006 07:13 PM
My new roller Scratch Bending, Forging,Extrusion... 3 10-07-2006 08:30 AM
