im going to buy a 10/22 grizzly lathemodel G0602 to do a cnc retrofit project need help selecting ballscrews and steppers/servos, and controller. any suggestions
Why buy a lathe just to retrofit it if you could simply buy a CNC lathe? I've seen decent ones for under $5K, and a friend of mine has one for sale. There are a lot of distinct advantages to buying a machine that was built for the purpose vs. changing an existing one. For instance, slant bed ways and enclosures, tool-changing turrets and no need to tune servos and spindles. You'd have feed-per-rev and threading right off the bat too, something you wouldn't get on that Grizzly without adding a spindle encoder.
Hi HG. The G0602 is an EXCELLENT candidate for CNC. It's a shame, that you will have to remove a lot of its parts, but the ultimate frame is a great CNC lathe. You should be able to CNC it for under $2K--including the lathe.
Here's my electronics recommendation:
http://crevicereamer.com/Page_71.html
http://crevicereamer.com/Page_85.html
CR.
Too many PMs. Email me to my name plus At A O L dot com.
thanks for your help crevice it was very helpful
CR - nice site. good info there. What gearing/ballscrew pitch are you recommending (if any) for driving the G0602 with the KL23H2100-35-4B 381 oz in motors?
I'm building a small lathe ( Granite surface plate lathe ) My ballscrews are Z: 4mm(.1575")/rev, X:2.5mm(.0984")/rev. I'm planning on direct driving the screws. I'm not sure how to figure out how much torque I need. Do you think I could direct drive with the 381 oz in motors?
Will
Hi Will. That lathe is an impressive project!
I'm using 5/8" 5 TPI BS, with 1:1 drive, which is the same as direct drive ratio. The 381s are super fast.
You will be using roughly 6TPI and 10 TPI screws--Pretty much in the same ball park. The 381 with 50V and a G540 should give some decent rapids with those linear slides--X will just be a little slower with higher resolution.
CR.
