Old 01-10-2010, 04:14 AM
Hellbringer is on a distinguished road
Internal Gear Cutting
I have figured out how to cut a normal gear but the project i am working on requires a internal spur gear. how would you go about cutting a internal spur gear.
thanks
Mike
Old 01-10-2010, 11:18 AM
Normally, internal gears are cut on a gear shaper. The cutting tools are made to cut the internal tooth form.
An internal gear can also be produced on a mill with a shaper attachment and a rotary table; a horizontal shaper with a rotary table mounted vertically; a vertical shaper/slotter or? Could also be produced on a wire EDM.
Be sure you know what the correct INTERNAL gear tooth form is. Your tool must match that form as the tool determines the form.
Dick Z
DZASTR
Old 01-10-2010, 11:34 AM
Andre' B is on a distinguished road
In addition to the above.
You can also rig an indexing disk to a lathe spindle and wheel the carriage in and out like a shaper.
Or if you are real patient you could layout the gear teeth, use a drill press and a scroll saw to rough it out then a die filing machine to finish to the line. It will get you something that looks like a gear but would only be usefull for slow speed crude power transmission.
Old 01-10-2010, 12:27 PM
cracker is on a distinguished road
http://www.google.com/url?q=http://w...nU7xy_q6qJ19BA
you can do this on a lathe (it's called a rotary broach made in michigan)
or use a "Polikely" check the videos out on a mill
http://www.tpsintl.com/poliangolar.h...FQkMDQod7Bsxhw
Tool for cutting internal keyways etc... M-man CNC Tooling 7 08-19-2010 10:05 PM
Problem- Mazak Space Gear G48 Internal Alignment FanucGuru Laser Engraving & Cutting Machines 0 12-05-2009 12:23 PM
Cutting Internal Splines? Krusty Karl General Metalwork Discussion 10 11-12-2008 11:32 AM
CUTTING INTERNAL GREASE GROOVE hoidahl General Metalwork Discussion 0 03-28-2008 01:13 PM
cutting internal gears mog5858 General Metalwork Discussion 4 09-26-2007 10:57 PM
