Old 04-04-2005, 08:19 AM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Attachment for moving a mill?
Well I need to move my milling machine for a flood cooling upgrade(catch tray under mill).My machine is a Harbor freight 800 lb. round column mill drill. The problem is that, (1.) not sure where to attach the chain. (2) not sure, for stress reasons, if machine can be moved with base still connected(one piece). I was thinkin I could remove the x and y tables to lighten things up or remove the base from the column. Didn't want to have to do that though. Can anybody help?
Old 04-04-2005, 10:18 AM
FLUTE HEAD's Avatar
Gold Member
Well I called hf and tech said to go ahead and lift the machine as one peice with a strap wrapped under the head and around the top of the column of the machine. Hope this helps anyone.
Old 04-04-2005, 10:56 AM
ViperTX is on a distinguished road
My preference would be to raise the base....the only thing holding the head onto the column is a rack and as I recall it's not pinned to the column since it is meant to swivel around the column if you decide to swivel the head.
Old 04-04-2005, 01:01 PM
FLUTE HEAD's Avatar
Gold Member
Thanks for the input. Actually there is also two bolts that assist in clamping the head to the column so that the column will not move while machining. I would think as long as these two bolts are tight the machine would stay put.
Old 04-04-2005, 01:10 PM
Ah, you are correct...forgot about those 2 bolts.
Old 04-04-2005, 03:55 PM
sendkeys is on a distinguished road
i would do it from the straps and the base :P unless there is a problem that you can't do it. :P
Old 04-04-2005, 05:35 PM
Wanna be
Hack is on a distinguished road
Just did a move myself
Just bought a mill very similar to yours. Weighs about 760 lbs according to the manual. Simply removed the thin cover around the pulleys (you'll probable have to remove the pulleys first) and lift from the head. I used a chain and an engine hoist (cherry picker type) and had little problem. Just be careful of the motor wiring.
Check out what I am working on at www.routerbitz.com!
Old 04-05-2005, 10:33 AM
FLUTE HEAD's Avatar
Gold Member
The first time I moved the machine I took the column fr. the machine and moved them separately. I used my cherry picker also, the only thing is halfway through the move I had to bleed the hydraulics. Talk about a time. This next time I'lle be sure and bleed the system before attempting. I also used a chain. But I'lle go with a sling on this round. thanks
how to mill angles? cowanrg General Metalwork Discussion 19 05-14-2007 10:35 AM
Tree Mill conversion Questions Flyinfool General Metal Working Machines 7 05-27-2005 11:37 PM
-VIDEO- Turning parts with a mill wisp General Material Machining Solutions 0 03-15-2005 03:26 PM
Any options for an old mill? bjorn General CNC (Mill and Lathe) Control Software (NC) 1 03-04-2005 11:55 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 05:07 PM
