Old 01-03-2010, 04:59 PM
morganj2003 is on a distinguished road
Question What's the best saw to cut Steel and Aluminum?
So, I'm a bit of a newbie, and I'd like some advice as to which saw I should purchase. I will be cutting aluminum tube (3/4" diam, 1/16" wall), steel tube (3/4" diam, 1/16" wall), solid steel rod (5/8" diam), and steel plate (22 gauge). Some of these pieces will have to be cut at angles.
That said, what saw should I buy?
I've done research myself and I've considered:
-A multicutter, like the Dewalt DW872
-A dry cut (cold cut) saw like Evolution (maybe the Raptor model?) makes
-Abrasive chop saw (I don't like these too much, as I prefer to have a smooth cut that the dry cut saws produce without a lot of sparks and dust)
-Putting a carbide blade meant for ferrous material on my Craftsman miter saw that spins at 5500 rpm (How many cuts do you think I could produce with this? I realize that I should be at a lower RPM for the carbide blades in steel, but I only need about 1000 cuts to get a good start with what I'm making)
-Putting an abrasive blade on my miter saw (I really don't like all the sparks, the mess from the abrasive blade dust, and the unclean edge left on the material. I also can't use this blade on the aluminum tubing.)
-Band saw (Doesn't cut as accurately, leaves a bad edge, and it's slow)
-Lathe (I need to cut at angles, and the lathe I have access to won't do this. Also, I found this method a little slow)
In the end, I lean toward purchasing a multicutter, like the Dewalt DW872, or a dry cut saw from Evolution. Perhaps, though, since I intend to make only 1000 cuts, I can get by with a carbide blade (maybe one from Diablo) on my miter saw? The problem I see with this is the ability to make continued cuts on the solid steel rod.
PLEASE ENLIGHTEN ME!!! Thanks MUCH!
Old 01-04-2010, 01:22 AM
Dorsal is on a distinguished road
http://www.mkmorse.com/ has the BEST steel cutting blades (Metal Devil) I have ever used, on a chop saw, no sparks, nearly no burr, no problem.
Go to the link, watch the videos and get one.
Tags
best saw, cold saw, cut steel, dry saw, evolution
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
RFQ - CNC Machined Steel & Aluminum Part HighCaliber Employment Opportunity 11 07-21-2010 01:38 PM
1018 Steel vs 6061 Aluminum trmpyro DIY-CNC Router Table Machines 4 01-30-2009 08:21 AM
PSI rating for steel and aluminum plate dave 21445 Mechanical Calculations/Engineering Design 27 07-08-2007 08:25 AM
Stainless Steel / Aluminum Cut and Rolled ukchris Employment Opportunity 3 01-18-2007 08:09 AM
new machine, aluminum or steel ? max_imum2000 Mechanical Calculations/Engineering Design 2 01-27-2006 07:29 AM
