Old 12-31-2009, 05:17 PM
frontrange is on a distinguished road
Worth converting from NMTB to Quick Change?
Recently upgraded my Lagun FTV-1 with an R8 to a much newer and servo'd FTV-2 with an NMTB40 and power draw bar. Lately I noticed the nose of the spindle is threaded on the outside, which I find means it is the later spindle design with a 4th bearing, all good, and the thread is apparently to take a Erikson quick change lock nut (which I don't have).
I'm not familiar with The Erikson QC system except from what I have been able to glean off of the net. It looks like if I had that lock nut I could use any 40 taper holder(assuming the flange was thin enough to fit the QC retainer or could be made so).
I'm wondering if maybe it would be worthwhile to get this spindle nut so I could open up my tool holder bargain hunting from just NMTB to any 40 taper piece out there. Is the QC system worth it or should I just stick with NMTB holders and my power draw bar?
Old 01-01-2010, 10:58 AM
I believe the Erickson quick-switch uses NMTB tool holders but might not take Cat V flange holders. I think the Cat tool holders have a thicker flange to accommodate the "V" groove for automatic tool changers. Maybe you can back off the Erickson nut to provide for a thicker flange? Or maybe I'm wrong. LOL
Dick Z
DZASTR
Old 01-01-2010, 11:30 AM
I think you are right. I went and looked at bunch of pics of CAT and BT holders on ebay and they all have the double flange that looks way too thick compared to a QC or NMTB flange. So I guess the QC lock nut wouldn't add anything in terms of additional holder options.
Old 01-06-2010, 10:48 PM
tizm is on a distinguished road
the quickchange option on my mill takes a 30 taper tool, not as sturdy as 40 but much better than r8
Old 01-07-2010, 04:00 PM
MrWild is on a distinguished road
While the quick change might be faster than a power drawbar, it isn't that much faster, and isn't automatic. I'd rather hit a button than yank a wrench, wouldn't you? Both require you to manually hold the tools as you remove and replace them and with the auto drawbar, you then just hit a button, versus the QC that needs the collar spun, then a wrench placed on it and tightened. Nope, not an upgrade in my eyes, and if it's faster, then faster is by a quicker man than i.
Nmtb-30 Quick Change Tool Holders Newby2 Bridgeport and Hardinge Mills 13 02-03-2011 09:16 PM
Need Help!- NMTB #30 Quick Change TowerCNC Want To Buy...Need help! 0 09-04-2009 01:22 AM
Converting a Grizzley Lathe to CNC is it worth it? Rich05 General Metalwork Discussion 2 07-11-2008 10:51 AM
NMTB 30 versus NMTB 40 Tooling MrWild General Metal Working Machines 4 10-11-2007 07:26 AM
quick change R-8? replicapro Benchtop Machines 10 04-14-2006 10:00 AM
