Old 12-30-2009, 05:53 PM
Dr. Jerryrigger is on a distinguished road
hi new here
I'm planing on putting together a small, crude, CNC milling machine for metal working. (there may be a more appropriate forum on here, but i couldn't fined it)
I still need to read a lot of info on here before i can figure out where i need to start. I'm planing on making this as inexpensively as possible, which i've found leads to a greater understanding of the equipment.
I don't have a high expectation of the first machine i make, i just want it to be able to make parts for a better machine.
Old 12-31-2009, 02:09 PM
kling8 is on a distinguished road
I have done some work on rebuilding some CNC's, I don't think it is worth it, and what your talking about trying to build one as cheap as possible, so you can build a better one, I would saw to find a machine that is used at a good price, and start producing parts. I guess unless this is just a hobbie. Take it or leave it, I just read all these people building machines and I don't see the up side to it, other than maybe a sense of accomplishment.
Old 12-31-2009, 05:44 PM
BrassBuilder is on a distinguished road
Your best bet is to start with a X2 if you want to learn and to keep the initial dollar investment down. Harbor Freight and Grizzley both sells them among other vendors. Keep in mind that you can't build a crude, inexpensive milling machine to make accurate parts.
I have found using inexpensive and CNC in the same sentence (or within the same topic) is a contradiction of terms for the most part.
Good luck...if the CNC bug bites, you are in for a good time.
Mike
