Old 12-30-2009, 04:56 PM
accuracymark is on a distinguished road
#40 taper Drive Keys
I bought a used Atrump Knee mill with a NT #40 taper. I came with both spindle drive Keys(dogs) missing. I just cant seem to be able to locate replacements. Does anyone know where I can get some?
Old 12-30-2009, 05:03 PM
mactec54 is on a distinguished road
Hi accuracymark
Just make them
Mactec54
Old 12-30-2009, 05:06 PM
Originally Posted by mactec54 View Post
Hi accuracymark
Just make them
Well I would but my milling machine is down because it needs drive keys.
Old 12-30-2009, 08:57 PM
Do you have a tool changer that you need the alignment to be right, you did say it was a knee mill, I have not seen there knee mills with a tool changer,
If you put a tool in the spindle & take light cuts you could make the keys, you may be able to get a piece of key steel that is the right size for the slot, cut them off with a saw & drill & counterbore a hole in them put them in & make some good ones
Mactec54
Old 12-31-2009, 02:56 AM
Good Idea, I will make up some temps and with them make good ones, No there isn't a tool changer.
Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread bdyenter General Metalwork Discussion 2 09-16-2009 08:10 AM
T-32 keys dead mbpp Mazak, Mitsubishi, Mazatrol 1 02-10-2009 04:14 AM
Build Thread- Hot Keys jmerson Dolphin CADCAM 4 01-15-2009 06:31 PM
O-MD quick keys help yoshi900 Fanuc 0 11-10-2008 07:24 PM
hot keys wireguy General CAM Discussion 0 05-22-2004 10:07 PM
