Old 12-24-2009, 04:14 PM
BiggerHammer is on a distinguished road
adding 4th axis to an existing mill
We just purchased a Rong fu 31 mill which was converted to CNC. It has three axes right now, driven by DC servos.
We have two possibilities for cash crops on the mill. Both require a fourth axis.
The existing axes are using Gecko G320X drivers. The cabinet that holds the controllers has space for a fourth controller, and the cabinet has cutouts for Axis A. I can't tell what kind of break out board I have, though; there was no obvious brand or model silkscreened onto the parts I can see. There is a label JAMECO on one of the larger components. I'll upload the pictures when I get them off of my phone (quality will be iffy ).
My question: what does one need to add a fourth axis? I assume that I would need a rotary table (what size?), a servo (what strength?), another G320X, and the wiring to connect the servo to the 320X. What am I missing?
Old 12-25-2009, 03:41 AM
TOTALLYRC is on a distinguished road
Looks like you have it all covered.
Other than setting up the ports and pins for the 4th axis you should be OK.
If you are short on pins then you may need a second pport.
You will need a step, direction, and possibly a home pin. Looks like 3 pins to me.
Mike
Old 12-25-2009, 09:18 AM
Thank you.
Need Help!- Adding 4th axis to Mini Mill RonThom Haas Mills 8 11-18-2009 08:59 PM
adding clearance to existing model Gncc50 Mastercam 8 01-07-2009 10:48 PM
Need Help!- Adding an X axis power feed to my smithy 1220XL milling table.Adding an X axis power matridium Smithy 0 05-28-2008 10:37 AM
Adding A 4th Axis helix77 EdgeCam 1 04-13-2006 02:36 PM
Lining up a CNC mill to an existing bolt pattern? youngfg General Metalwork Discussion 8 11-07-2005 02:05 PM
