Old 12-20-2009, 10:43 AM
Hastx is on a distinguished road
Bearings
I'm looking to build some tooling for my shop. I was wondering what bearings to use. Basically I'll be building an axial or straight live tool for a lathe. Cost is important but i dont want to have any end play in the assembly.
Old 12-20-2009, 02:52 PM
scotta99fan is on a distinguished road
I'm not certain what you are actually doing, but thrust bearings will take the most axial load.
Old 12-20-2009, 04:28 PM
Hastx, if you are referring to an axial tool like a drill, you will need axial (thrust) bearing capability as well as radial capability. This can be accomplished with tapered roller bearings or with angular contact bearings.
The same can be accomplished with axial thrust bearings in combination with radial bearings in the assembly. Probably will have to pre-load the assembly as well.
Dick Z
DZASTR
Just IN- v bearings in at VXB blackbeard52 Product Announcements & Manufacturer News 2 07-16-2009 08:07 AM
DIY air bearings daedalus Mechanical Calculations/Engineering Design 9 07-30-2006 10:44 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Double Bearings Or Quad Bearings? ballscrewed Mechanical Calculations/Engineering Design 5 04-18-2006 12:33 PM
Bearings (Radial Ball Bearings) The Bearing Man CNCzone Club House 0 12-18-2005 12:10 PM
