Old 12-15-2009, 07:19 PM
turbo2ltr is on a distinguished road
Fixture for PVC sheet
I need to mill some PVC sheet and pipe.
My first question is what technique do you use to hold your workpiece when you have to go past the bottom? In the past, while not very accurate (which was OK for the application) I clamped the part onto a piece of masonite so I could mill past the edge into the masonite. When accuracy is important, I assume the same thing is done, but with something like aluminum plate? My issue is I typically do one-off parts so I can't be making new aluminum fixture plates for each part.. that might get expensive...any other ideas?
My other issue/question is my mill does not reach the bed. I need about 3" of height off the bed. It's fine if the part fits in the vise, but for this sheet I have to mill, I can't put it in the vice. Short of getting a 18x18x3 block of aluminum, are there any other tricks you guys use for something like this?
Thanks,
Mike
Locating Fixture 123sxu Work Fixtures and Hold-Down Solutions 10 06-04-2009 10:18 AM
Made a fixture, fun :) SpeedsCustom Benchtop Machines 31 10-13-2008 05:51 PM
NX5 Fixture Offset H234 General CAM Discussion 5 03-27-2008 08:12 AM
fixture question fourperf Haas Mills 10 02-25-2008 05:18 PM
My New Low Cost Fixture petriej Work Fixtures and Hold-Down Solutions 2 09-10-2007 11:56 AM
