Old 12-15-2009, 02:16 AM
ranchak is on a distinguished road
Removing Swarf in Coolant
I just installed a flood coolant sytstem on my BP Series I CNC Mill. My problem is the swarf clogs the drains in the table. I can let the swarf run into the coolant tank, but I'm afraid of clogging my pump, even with a filter. Any ideas?
Old 12-15-2009, 04:43 PM
mactec54 is on a distinguished road
Mount a strainer ( like a kitchen type strainer) in another container so the drains from the machine go into it, have some holes in the container up near the top below the strainer, this will get most of the chips out, put a magnet in a plastic bag that will get any steel fines that don't get in the strainer put a fine strainer on the intake of the pump
Mactec54
Old 12-15-2009, 11:55 PM
Thanks for the idea, tonight I made a swarf reservoir tank that I mounted just below the table drain height. I removed the screens in the table and the table drained alot quicker. I need to changed the outlet on the upper tank so that most of the swarf will filter to the bottom of the tank. I plan on installing a screen like you suggested to get the swarf as it comes from the table. I'll then use a down-turned elbow that will be below the coolant level, hopefully this will allow the swarf to settle and not get carried down stream to the pump tank.
Old 12-16-2009, 08:36 AM
Hi ranchak
That will help get your chips out of the coolant but you don't need to have it outside the main tank, you can mount it inside the main tank even 2 reservoir containers with strainers if one is not enough
Mactec54
Old 12-16-2009, 11:04 AM
That's something I may consider, right now my "system" is a temporary build. I'm using a 5 gallon plastic bucket for the main reservoir and a cat litter bucket for the second reservoir. Once I get things where they work I can combine them into one unit. The biggest thing is I want to be able to check/clean the swarf while the unit is in operation. I haven't been able to come up with a good idea yet.
Table tray for coolant/swarf protection.... InspirationTool Benchtop Machines 12 02-12-2011 09:35 AM
Homebrew swarf air blower & coolant pump guru_florida Benchtop Machines 34 05-28-2010 01:20 PM
Removing swarf automatically from long bore markkirby General Metalwork Discussion 11 08-10-2008 07:13 PM
Removing coolant stains from clothing? Cyre General Metalwork Discussion 7 03-18-2007 09:47 AM
Coolant & Swarf problems on Homebrew CNC Systems UKRobotics General Metal Working Machines 1 01-17-2005 11:26 PM
