Old 12-02-2009, 03:53 AM
jeff8451 is on a distinguished road
Makino fnc100 A20 Cat 50 Retention knob mechanism.
I have a Old Makino Mill That I have retrofit using Rutex drives
Makinoi Model fnc100 A20.
My problems:
1 retention knob mechanism
2 Better spindle motor control
1 There are two lines going to the draw bar mechanism(it was hydraulic). I am using air. One line does nothing, the second line draws the mechanism tight. Does anyone have a schematic of this? How does it come apart? could a small hydraulic motor fix this for me?
2 I want to use a KB electronics spindle control. The problem is there are two fields, and both have alot of resistance. 20 ohms and 5 ohms. The 20 ohm winding is the main winding, and the one I am using. I have the motor controled using a large potentiomenter hooked parallel with the field winding. I have also connected the feild in series with the arnature. This keeps the arnature from being over amped. and controls the motor pretty good. Can someone think of a controller I could use? I would rather not have the motor rewound. ty
I have mill pics on myspace look up jeff35m_73068@yahoo.com
ty jeff
ATC Retention knob JerryFlyGuy Mechanical Calculations/Engineering Design 39 04-07-2009 09:58 AM
interact 4 pull stud/retention knob style? camarogod98 Bridgeport and Hardinge Mills 0 02-16-2007 03:50 PM
Retention Knob Cross Reference for 50 Taper? pdoherty Haas Mills 2 12-13-2006 10:54 PM
Retention Knob Help 1gonzo Machine Problems, Solutions , Wireless DNC, serial port 1 03-17-2006 10:44 AM
Retention knob breakage Crash General Metal Working Machines 3 11-03-2005 02:12 PM
