Old 11-27-2009, 12:41 PM
firepoker1965 is on a distinguished road
CNC "twist"
Can someone explain in simple machine terms what "twist" refers to when discuusing "The twist in a CNC machine"
Old 11-28-2009, 02:02 PM
nakatome is on a distinguished road
twist is when the machine is setup/installed it is leveled and tramed with indicator watch movement as the x,z,y axis move you try to adjust the twist out of the frame with machine bolted to floor , and adjusting leveling bolts. i hope this helps
nakatome
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
G320 "common" or "+5vdc" why do they vary? beezerlm Gecko Drives 3 01-12-2008 04:00 PM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
