Old 03-25-2005, 11:51 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Sieg X3 quill problem
My mills quill has a bit of play, did any of you owners of this machine need to adjust it out? If so how did you do it? I can move the bit a few .001 and when I tried to cut a piece of steel taking .020 or so the bit was moving off from the direction of cut.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-29-2005, 02:39 PM
steveg is on a distinguished road
Is it the quill it's self or the spindle shaft(bearing play) thats moving?
A dial indicator mounted on the head casting, first against
against the quill ,then against the spindle shaft or
tool holder will tell.
Old 03-29-2005, 02:46 PM
CNCadmin's Avatar
Site Owner
I can get movement right at the tool bit installed in the holder, so I believe it's the bearings. It looks like that bearing can be adjusted for preload??
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-30-2005, 06:49 AM
would it be possible to post a copy of the relevent page
in your manual.
Is the tool seated properly in the taper
sometimes the little spindle key that fits the groove on R8 tools
is set to far out or the groove on the tool is not deep enough
Old 03-30-2005, 08:40 AM
CNCadmin's Avatar
Site Owner
I'll try to scan it and post it.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 02-09-2007, 08:45 PM
mugabe is on a distinguished road
How did you solve the problem ? I have similar for X2 machine .
Okuma LC-20 Threading problem Gunner Machine Problems, Solutions , Wireless DNC, serial port 13 12-13-2011 11:11 PM
Comunication problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 4 03-31-2011 04:25 PM
CNC gantry Machine shows problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 15 04-25-2005 04:02 PM
Communication Problem Alex S.A Computers and Networking 2 01-28-2005 10:38 AM
Fadal VMC4020A axis problem cwww Machine Problems, Solutions , Wireless DNC, serial port 16 12-02-2003 12:07 AM
