Old 11-24-2009, 09:22 PM
Micro Milling is on a distinguished road
CHeap vice for Micro mill?
I just ordered a harbor freight micro mill X1.
I will be using this Mill to make some cuts in brass locks, like making square holes in the lock body case.
I was wondering if I really need an expensive vice or can I just clamp it down with anything? The holes do not have to be perfect but just look straight and everything look even.
I was also wondering what would be the best type of end mill bit to cut small holes in brass locks, the holes are about 1 inch by .5 inch square holes. The thinkness of the brass is maybe .2 to .4 inches in thickness. What size and type would work best?
The pictures below is of a lock that I will try and make similar cuts.
Old 11-25-2009, 10:20 AM
Zap Zap is offline
Zap is on a distinguished road
Clamp your part directly to the table. You don't need a vise at all. Use a dial indicator to square it up. Touch the indicator to your part and move the table back and forth. If the measuring surface is not flat just work off an average. Don't fully tighten your clamps until you have it "squared". Use a hammer or mallet to tap it to move it a little. Once you are happy with its position, tighten the clamps fully and double check your work.
Use a bigger end mill to rough it out. 1/4" looks like a good size to start with. Then go as small as you want to finish it up and get a small radius on the corners. Looks like a 1/8" end mill should work well but you can go smaller.]
Remember that you don't have to cut completely thru the part in one pass for the initial cuts. Won't be so much tool chatter and deflection if you mill it down in "steps". Take off like .020" at a time. Once you cut thru the part and have the basic shape cleaning it up with the smaller mill will be easy.
CHEAP X1 MICRO-MILL SPARE PARTS SET kreutz EBAY ADS 2 10-01-2009 02:19 PM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-22-2009 11:14 PM
pin vice / micro chuck question ptxman General Metalwork Discussion 1 05-26-2008 08:06 PM
Need help with a HF micro-mill mondo50 Benchtop Machines 3 08-26-2005 09:52 AM
Very cheap Bipolar Micro-stepper board Stevie General Electronics Discussion 5 07-13-2004 05:39 PM
