Old 11-17-2009, 12:26 AM
gurdis is on a distinguished road
newbie questions
Hi, forum,
I was looking for the cheapest way to get a cnc machine that can cut all sorts of metal, even if it takes weeks to do it. The first thing I want to mill is a 6" cylinder with radial holes, and also a cylinder with a groove along the inside. On ebay I found some cheapish rotary tables. Some palmgren tables even have x and y screws, so I would only need to make or buy a z axis. I've got a big (60kg and seems quite rigid) bench drill press that could be modified with a leadscrew and stepper motor to provide spindle with Z axis. I'd just bolt the rotary table to the drill press table. Does it sound like an ok cheap starting point for cnc conversion? I want to make small engine parts, so it's got to be "pretty" accurate (don't know how accurate).
2nd question, does the rotary table make it more difficult to find cheap drivers or software?
3rd question, if I want a rotary table on ebay but seller will not ship outside US, is anyone willing to forward a package, to Norway?
Regards, Gurdis
edit: and is this a proper forum for this post?
Old 11-17-2009, 07:50 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Yes that will work.
No it will not work "well".
There is no such thing as cheap AND accurate. Pick one and that is what you will get.
If you want to make engine parts and do not want to spend money on a machine you better have someone else make the parts.
Sorry for being blunt
www.integratedmechanical.ca
Newbie- CNC Newbie Questions Smokingman K2CNC 7 08-21-2009 03:49 PM
Several newbie questions. bill-the-cat Taig Mills & Lathes 12 08-09-2009 11:27 AM
DIY Newbie Questions g00bd0g DIY-CNC Router Table Machines 3 03-21-2007 01:18 AM
Few newbie questions about CNC thedonutman Musical Instrument Design & Construction 4 02-12-2007 12:15 PM
Newbie Questions Sanghera General Electronics Discussion 4 04-17-2005 02:44 PM
