Old 11-11-2009, 12:49 AM
Nateg281 is on a distinguished road
X2 Hydraulic powered drawbar idea....
So I've been looking around online and this forum and I've only seen one attempt at using hydraulics to release the drawbar on the X2. So here's my idea. Use a low profile hydraulic jack like this one mounted on the top of the milling head:
http://www.harborfreight.com/cpi/cta...emnumber=95978
I think if I can figure out a way to push the fluid using an electric actuator located off the mill inside the enclosure I plan on building, it would make the mass added to the X2 mill head very small and easy to mount. Also I figure if the actuator was large enough in diameter that amount of travel would by very very little as the mass of fluid to be pushed would be very little. The travel is only 1/4" on this low profile jack and I'm not sure how much travel people like Hoss have in ther pneumatic drawbar.....
Any ideas? criticisms? thoughts or ideas? Let me know what you guys think.....doable?
Old 11-11-2009, 05:17 PM
Hayworthmilling is on a distinguished road
I believe that jack is single-acting. You'll need a double acting ram to eject the tool.
It also doesn't come with pump. I think pneumatics would simplify things significantly.
Old 11-11-2009, 05:29 PM
Yeah, the more I think about it the better a pneumatic drawbar looks. I just don't have a compressor now and was trying to invent something that didn't require one. I do believe that that ram is single acting. Why is it, though, that my idea would require a double acting ram? Is it because there is no force to return it to the "up" position after the release?
Old 11-12-2009, 05:59 AM
kawazuki is on a distinguished road
You guys complicate things to much! Think about hydraulic clutch in your car or motorcycle...... push the pedal, clutch moves out, let go and clutch engages!
A spring return is a wonderful thing! LOL
Funny enough this was pretty much my solution I came up with over the weekend except i'm gonna use a foot operated pedal and keep both hand free using a m/cycle clutch slave and a modified master cylinder and pedal. Bonus is this is really light in weight so ideal on the smaller mills!
Old 11-12-2009, 08:25 AM
You have to post pics of that clutch idea if you build it. I'd really like to see how that works.....
Old 11-12-2009, 01:56 PM
SScnc's Avatar
SScnc is on a distinguished road
That is exactly how mine works, the spring forces the piston back into the cylinder.SEEN HERE in the first picture, the piston on the left has the spring on it.
And, the hydraulic clutch slave cylinder I remember from a 3/4 ton Chevy truck I had back in the 80's is where I got the idea from to do this on my X2.
Post some pics of this when you guys do it.
Old 11-12-2009, 04:02 PM
MrWild is on a distinguished road
Still too complicated. Last night while falling asleep it it me. Air over hydraulic. A 100psi air, four inch stroke cylinder of 1.125 bore pushing a second piston of 3.625" dia. using hydraulics, will develop over 1000lb of force and move the 3.625 piston .375".
You piggy back the two cylinders and make the 1.125 piston hollow so it gives a spring room to go during the down stroke. The bottom of the spring rests on the large 3.625 piston. When air pressure is removed the spring forces the 1.125 piston back up and even though it's base rests on the large piston, the large piston will still retract because the small piston is moving 4" versus the .375 of the large one.
You only need one air line, it all sits on top of the head, and can be run with Mach through an air solenoid. Depending what your junk pile has, pretty easily done.
Old 11-12-2009, 05:41 PM
SScnc's Avatar
Too complicated ? I think my setup is extremely un-complicated.
As for it "all sits on top of the head", that is exactly what I wanted to eliminate. To have the lightest, smallest unit actually on the head. To that end, when I have time I'll be making a much smaller and more compact slave cylinder that is also easy to attach and remove from the head.
As for you description, you may want to look at post 20 HERE and the link in it may be what you have in mind, I'm not sure.
X2 Electric-*Hydraulic* drawbar SScnc Benchtop Machines 34 11-26-2009 05:45 PM
Battery Powered CNC Geof Phase Converters and VFD 6 06-06-2009 10:33 AM
AC powered drives nelZ General Electronics Discussion 3 07-18-2008 05:14 PM
Finished Powered Drawbar for my mill... BobWarfield General Metalwork Discussion 52 02-27-2007 10:34 AM
Under Powered Journeyman 325?? homchz Tree 5 12-25-2006 01:20 PM
