Not that I have run across, most people who have run regular cnc machines have a hard time with them because it is so easy( no g code) enjoy your proto trac I have been using them since the early 90,s
I am wondering if there are any other machine cnc controls as easy as the ProtoTRAK control...
I like how easy it is to make and change programs on the ProtoTRAK for small-lot runs and prototyping stuff.
how are the prototrak mills.. like the DPM series? are the knees mills okay?
I have a fhm 3 axis bed mill smx and a retrofit 2 axis bridgeport I have had no problems been using proto tracs since the early 90,s
where are you located? I'm looking to buy a prototrak bedmill or sub work out if you are near..
severn maryland call thomas harpine410 487 1364 he is the local dealer
severn maryland call thomas harpine 410 487 1364 he is the local dealer
