Old 10-21-2009, 02:28 PM
KMachine is on a distinguished road
Yama Seiki Quill Alarm
First time using the quill on the tailstock today and getting the following error.
No. 2024 QUILL ALARM (A5.0)
The manual doesn't list this alarm. Anyone dealt with this alarm before? I'm still waiting to hear back from the dealer of the machine.
Thanks.
Old 10-28-2009, 10:35 AM
PMT PMT is offline
PMT is on a distinguished road
Probably need to adlust the limit switch for the quill. should be under the plate on the body held on by too many bolts. Typically you would adjust the switch so it is made befor the end of quill stroke then position the body so switch is made when quill is pressed on part. This way if part is a little short you will get alarm rather than toss part out of machine.
Yama Seiki smilenbseen General Metal Working Machines 23 09-13-2011 09:31 AM
Need Help!- Yama Seiki Turret Adjustment KMachine General Metal Working Machines 2 10-21-2009 02:08 PM
Hitachi Seiki Alarm Help! stevo1 General CNC (Mill and Lathe) Control Software (NC) 0 06-16-2008 08:09 AM
Hitachi Seiki alarm code help atrus General CNC (Mill and Lathe) Control Software (NC) 0 05-29-2008 09:49 AM
Seiki 4VS Quill Handle TZ250 Milltronics 3 02-10-2007 03:58 PM
