Old 10-20-2009, 01:33 PM
misasi is on a distinguished road
Can this work?
Well im sure this has been asked before but i could not find any answers through the search.
What i would like to do is CNC plastics and maybe some aluminum. I would like a table surface about 8"x8" or around there for smaller things.
For a while i have been considering building my own table but i figured accuracy would suffer from the DIY mix mash of parts.
Now here is my idea. On HF i found a 5" Drill Press Milling Vise. It has travel of 8'' (X) & 7'' (Y). Would it be possible to convert this milling vise to a cnc and create my own gantry for the cutting tool? The only issue i see is that there might be a lot of slop in the x y movements of the vise but i think with some careful planning it could work.
BTW this is an awesome community here. This is my first post but over the last few years i've been in and out while decided if i want to go ahead or not with the build.
Old 10-20-2009, 01:45 PM
MrWild is on a distinguished road
Yes but.... the screws are sloppy and the huge amount of back lash is impossible to tighten up without going to new lead screws which would also mean you would need to have machine work done to the table in order to adapt the new screws. Then you have problems with sloppy gibs which add even more problems to inaccuracy. The drilling table you found is the peak of POS positioning tables and the rest (vise less positioning tables) have the same problems described.
Newbie- Work Planes / Work Coordinates MICFDI Esprit 9 05-11-2008 11:35 PM
cnc art work micheliron CNC Plasma and Waterjet Machines 17 03-07-2008 07:23 PM
Looking for work forrey45 Canadian Club House 0 01-08-2008 05:26 PM
Looking for work JPMach Employment Opportunity 1 09-01-2006 12:47 PM
would this work? shootingarts DIY-CNC Router Table Machines 1 12-31-2005 05:22 PM
