Old 10-19-2009, 02:26 PM
Azor is on a distinguished road
South Bend Magnaturn 1218
South Bend Magnaturn 1218. I just replaced the bearings in the load adapter, between spindle pump/motor and spindle. Lathe sounds great, but I noticed in my new 1218 parts and assembly manual that the load adapter originally was to be mounted via rubber encased vibration damping standoffs,which mine does not have. Just solid steel. Was rubber mounting discotinued for some reason? Or vice versa? The last load adapter bearings did not fare well. I'll probably have to pull the adapter mounting plate to modify it to accept the rubber style, so I thought I'd ask if that would be going in the right direction before I do any damage. My machine is s/n # 12, so it's an early machine that was rebuilt at South Bend around 2000. But were the standoffs retrofitted?
WTB South Bend Magnaturn Artty62 Want To Buy...Need help! 6 02-22-2011 03:54 PM
Help with South Bend Magnaturn CNC lathe Fudd General Metal Working Machines 26 07-15-2010 08:25 AM
Need an info on South Bend Magnaturn 612 terrym CNCzone Club House 4 09-29-2008 03:04 PM
South Bend Magnaturn 612 htral General Metal Working Machines 1 07-23-2008 11:14 AM
Anyone know the South Bend Magnaturn 612? dcencer General CNC (Mill and Lathe) Control Software (NC) 1 12-29-2007 12:05 PM
