Old 10-16-2009, 11:35 PM
dannifer.ebot is on a distinguished road
NEWBIE: HELP ON HELICAL MILLING
HELLO GUYS!
CAN SOMEONE SHOW ME SOME SAMPLES OF HELICAL MILLING? JUST THE BASIC HELICAL MILLING PROCESS USING FANUC CONTROLS. THANKS
Old 10-16-2009, 11:40 PM
chadwiggan is on a distinguished road
The simplest way to achieve helical motion is by X and Y circular interpolation (G02 or G03) with a Z value added per revolution. Use an I command to specify the distance in X from the starting point to the center of the arc. To cut a complete circle of 360 degrees, do not specify an ending point for X or Y. If you use incremental positioning (G91), you can loop the cycle to achieve your depth using an L command. Here’s a sample program:
O1234;
(Helical Milling Example);
T1 M06;
G00 G90 G54 X0. Y0. S3000 M3;
G43 H01 Z0.1;
G00 X0.5;
G91; (incremental positioning)
G02 I-0.5 Z-0.25 F20. L4; (helical motion, 1 in. dia. x 1 in. deep)
G00 G90 X0;
G0 Z0.1 M09;
G53 Z0.;
G53 Y0.;
M30;
CHADWIGGAN
Old 10-17-2009, 12:11 AM
Smile great help
thanks it is a great help.
just wanna have an idea on how to do helical milling. thanks a lot
Helical Milling on VR-40 abealz Okuma 2 10-06-2009 07:10 AM
Problem- Helical Milling mikepaubuchon CNC Swiss Screw Machines 4 09-26-2009 08:56 PM
Helical Milling binzer GibbsCAM 3 03-30-2007 04:39 PM
Helical milling with HAAS dinger G-Code Programing 10 06-19-2006 01:36 AM
helical milling hogman GibbsCAM 4 04-21-2006 08:15 PM
