Old 10-14-2009, 06:28 PM
KMachine is on a distinguished road
Yama Seiki Turret Adjustment
Has anyone every had to realign the turret on a Yama Seiki GA-2000? Had a crash and need to realign. The manual with the machine provides very little information.
Old 10-19-2009, 02:08 PM
PMT PMT is offline
PMT is on a distinguished road
Radial Alignment - Remove cover center of turret. Remove 2 taper pins with slide hammer. Loosen bolts for curvic coupling. Run indicator on OD tool slot parallel to x axis.
Run X up and down and move turret accordingly for 0 reading. If turret "clunks when indexing (ie not going into curvic cou[ling properly) Yama Seiki in CA. has step by step procedure to re-zero turret servo. Very easy to follow.
Axial - run indicator on boring holder servace parallel to Z axis. If need loosen 4 or 6 bolts holding turret Assy to X axis slide. Adjust turret assy to be parallel with Z axis. I believe there is a jacking block on the tailstock which can be removed and placed on turret for use aligning turret.
Old 10-21-2009, 02:08 PM
Thank you for the information.
Yama Seiki smilenbseen General Metal Working Machines 23 09-13-2011 09:31 AM
lathe turret adjustment/alignment help!!! thum31 Haas Lathes 0 06-28-2009 08:24 AM
turret servo adjustment..... theemudracer Fanuc 1 05-16-2008 11:39 AM
Mori Seiki SL 0H turret tapserv Mori lathes 4 01-20-2008 01:01 PM
