Old 10-13-2009, 07:43 AM
sami75 is on a distinguished road
Turret problems
Hi. I have a "Mazak super quick turn 250 ms" yaer 1998. When i rotate the turret manually with the fwd/ccw button the turret works fine and tool positions is correct at display. But if i trying to change tool in mdi mode the turret start rotating with high speed and stops att wrong number. it sounds like it doesent clamp. i need to reset... then it clamp. I get alarm 272 and 221 I tried to shift the clamp/unclamp valves.. worked 3 times.
Need Help!- TURRET PROBLEMS sami75 Mazak, Mitsubishi, Mazatrol 4 03-10-2010 12:21 PM
Hardgine CHNC II turret problems CatesMetal Bridgeport and Hardinge Mills 5 08-28-2009 07:14 PM
Star VNC 20 turret problems tech5028 CNC Swiss Screw Machines 1 06-16-2008 10:07 AM
TL-1 Turret problems RDemets Haas Mills 10 04-28-2008 02:46 PM
Turret alignment problems coquina Haas Mills 15 07-17-2007 06:53 PM
