Old 10-06-2009, 08:31 AM
soundmotor is on a distinguished road
Question Opinions: wood chop-saw to metal chop-saw duty
I picked up a heavy-duty Makita chop-saw at the dump. It is old & weighs at least 50 lbs. It is not a sliding type, just the basic chop with miter table. It needed some fiddling with the switch but runs fine now. The miter feature is broken though and it needs ~$50 in parts to get back to normal and is stuck @ 90-degrees. My thought is to make it into a metal cut-off machine. By seat-of-the-pants it seems to turn at similar RPM to chop-saws I've used previously.
Any downsides on this idea?
Old 10-06-2009, 09:00 AM
Will work fine with what is called a 'triple chip blade' rated for cutting non-ferrous metals. Just make sure you have something to securely clamp the material you are cutting. Use a bit of coolant either with an ait mister or just spray it on before cutting.
Old 10-06-2009, 09:42 AM
Thanks Geof, excellent reminder on using clamps!
I should have specified I want to use this on mild steel such as angle & bar stock. I don't think the triple-chip blade would work for that.
Re: coolant, I've never seen it used on a true chop-saw with an abrasive cut-off blade as below. Can you use coolant with an abrasive blade?
Old 10-06-2009, 11:24 AM
You might make one cut on mild steel with a triple chip blade.
Coolant is not needed with the abrasive cut-off blades.
Old 10-06-2009, 11:30 AM
Welder1 is on a distinguished road
careful
I have used an old chop saw to cut metal with an abrasive blade before. The one I used was originally made for wood, and it worked just fine. The only issues I had were that the saw had plastic chip shields in the bed and part of the blade guard was plastic too. The hot metal from the abrasive blade melted it a little. No harm though.
Old 10-06-2009, 01:59 PM
Great, that's what I needed to know.
All responses very much appreciated.
I will probably pick up a triple-chip blade for when I do work with non-ferrous stock.
Metal Cutting Chop Saw vs Abrasive Chop Saw diarmaid Metal Working Tooling 41 05-14-2010 02:03 AM
should I chop up these MASSIVE linear rails? KTP DIY-CNC Router Table Machines 8 03-01-2009 12:14 PM
best basic chop saw nc9933 General Metal Working Machines 8 11-02-2008 02:10 PM
New Machine Build- Radial arm chop saw - bad idea? roombacurious General Metal Working Machines 12 08-14-2008 07:26 PM
Need a saw to cut material, Band or Chop? mgb1974 CNCzone Club House 11 07-29-2008 11:22 PM
