Old 10-05-2009, 11:02 PM
iaknown is on a distinguished road
Installing and Preloading Ballscrew??
Hello all, I recently purchased a Mighty CNC vertical mill, model is the Mustang, similiar to say a Fadal 3020. Unfortunately I had to almost completely disassemble the entire machine to get it down the hall and out of the building it was in. This included pulling out the Z-axis ballscrew to gain some height. I reinstalled it the other day but held off on tightening the end nuts because I wanted to get some input. There are the carrier bearings and then outside of them is where you tighten the nuts to preload the ballscrew. How much should one end be preloaded against the other? Or how much should the ballscrew be stretched, if any? Any rule of thumb because there is nothing in the manual about it and support for this machine sucks. Thanks in advance guys.
Old 10-05-2009, 11:13 PM
HuFlungDung's Avatar
Moderator
I would tend to go by 'feel' of the screw, as you roll it over by hand. Ideally, the ballnut should not be fastened to head, and the motor should be uncoupled when you do this. That way you won't be fooled by other factors that mimic fake tension on the screw.
So bring the tension up on the screw bearing blocks until you eliminate freewheeling of the screw when you spin it by hand. Give it a bit more tension up to the point where you begin to notice it takes a firm grip to turn the screw, but not so far that you need to use mechanical advantage (ie, a plier or wrench) to turn it. Hook up the motor and attach the ballnut to the head and program full length rapids on that axis for 100 repetitions. Observe the noise level and rate of heat buildup in the bearing housings.
Old 10-06-2009, 11:55 PM
Man, that sounds a little scary to me...I mean I'm not doubting you at all but I'd be too uncertain about going by feel since I'm not familiar with these at all. It's a low-end machine but still was an expensive one and I'd hate to have it fail in a year or so because I didn't set it up right. I was hoping there was a more accurate foolproof way....
Old 10-07-2009, 10:11 AM
Moderator
Well when it comes to preloading high speed bearings, they won't stand very much. But running with zero preload won't locate the rotating part. So find somewhere in between
Factory might have had an inch-ounce torque spec at which the ballscrew should turn at when its properly stretched. But without that number, what are you gonna do?
Monitoring heat buildup is the best way to check the preload on bearings because too fast of a heat rise is going to damage something, or introduce heat into the ballscrew, which will spoil the preload.
Installing and Preloading Ballscrew??? iaknown Linear and Rotary Motion 0 10-02-2009 09:25 PM
Preloading haku DIY-CNC Router Table Machines 5 03-13-2008 04:03 PM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
Preloading ball screws. eman5oh Linear and Rotary Motion 2 01-13-2006 09:10 PM
Preloading 5/8" thomson ball screw TommyB DIY-CNC Router Table Machines 1 12-06-2004 09:29 AM
