Old 03-13-2005, 09:33 AM
mtechserv is on a distinguished road
30 taper tooling
I recently purchased a Clausing CNC mill and I'm in the process of setting it up. I takes ISO 30 taper tooling. I'm a little confused because there are so many different types of 30 taper tooling. I realize that the actual taper is the same on all of them. However, there are different flange types.
I've seen BT, NMTB, Erickson, and CAT V tooling. Which ones are interchangeable, and which ones would fit my machine?
Old 03-14-2005, 08:02 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Does this machine have a manual drawbar? Is it the threaded end type? If not what sort of pull stud does the machine use? Does this machine have an automatic toolchanger?
www.integratedmechanical.ca
Old 03-14-2005, 11:42 AM
The drawbar is pnuematic (Kurt brand). So, it is threaded and does not use a pull stud.
There is not a toolchanger, as this is a CNC knee mill.
The toolholders that were used in the machine (they didn't come with the machine) looked similar to a BT. There was not a straight shank above the taper, as with the NMTB.
I beleive the BT will fit, but I'm not sure about the difference in the flange between the CAT V and the BT. Why are these flanges different?
Old 03-15-2005, 08:41 AM
DareBee's Avatar
You will be able to use any 30 taper tooling you want with 1 possible glitch in your situation. You will have to make sure that your thread is either metric or imperial to match your drawbar and that your drawbar will catch enough threads on the toolholder or on the other hand be threaded through too far.
Example: I have a 40 taper machine here that I use ISA, BT, & CAT tooling in. The ISA & CAT are imperial thread and the BT Metric. I have 2 drawbars, 1 metric and 1 imperial. Also my drawbars have a jam-nut on the top end so I can adjust the screw length because the ISA is about an inch longer than the CAT but uses the same drawbar.
You having a power drawbar kinda leaves you stuck with picking 1 style and making it work.
The flanges on the holders are only of importance if you have a machine with a toolchanger as the changers are designed to grip the tooling on its flange characteristics. Toolchangers are commonly designed to hold either CAT or BT.
Hope this helps
R2E3 Tooling dfmiller Bridgeport and Hardinge Mills 16 05-29-2005 04:51 PM
CNC Router Taper Machine hadjcues DIY-CNC Router Table Machines 8 03-23-2005 05:02 PM
R8 taper lt paul General Metal Working Machines 2 06-10-2004 10:31 AM
best tooling purchases made for building your CNC machine pminmo DIY-CNC Router Table Machines 15 04-09-2004 09:28 PM
Where do you buy tooling? NeoMoses CNCzone Club House 8 10-08-2003 06:21 AM
