Old 09-30-2009, 10:36 AM
loedward22 is on a distinguished road
counter-clockwise vs clockwise arc problem
If I run a simple program (example below) that cuts the same circle in clockwise and counterclockwise directions, the result is a shift on the y axis like the illustration I have drawn. I've been stumped on this problem for weeks and have narrowed it down to this simple problem. I've considered many possible causes but am beginning to think its the way the control interprets the code (Centroid M39). Has anyone encountered anything like this before?
example G-Code:
N100 G20
N110 G0 G17 G40 G49 G80 G90
N120 T1 M6
N130 G0 G90 G54 X4.8943 Y2.5 S3000 M3
N140 G43 H0 Z.25
N150 Z.1
N160 G1 Z-.25 F6.
N170 G2 X.1057 R2.3943 F12.
N180 X4.8943 R2.3943
N190 G1 Z-.15 F6.
N200 G0 Z.25
N210 Z.1
N220 G1 Z-.25
N230 G3 X.1057 R2.3943 F12.
N240 X4.8943 R2.3943
N250 G1 Z-.15 F6.
N260 G0 Z.25
N270 M5
N280 G91 G28 Z0.
N290 G28 X0. Y0.
N300 M30
Resulting Shift:
Old 09-30-2009, 11:40 AM
littlerob's Avatar
littlerob is on a distinguished road
I don't know where your offsets are or what diameter your tool is, but the first thing I would try is using "I" and "J" commands instead of "R". The best reason for this is you can complete an entire circle with one line of code.
Hope that helps, I think it will, Robert
Old 09-30-2009, 11:45 AM
I've tried switching to I and J and had the same issue. The tool is 1/4" end mill, but the problem is the same with other tools. Oh, and I'm not using diameter offsets.
Old 09-30-2009, 11:50 AM
Runner4404spd is on a distinguished road
i think your problem is backlash. how round is the hole to begin with? also cut it alot slower and see if it helps. i had a similar problem on my IH mill. apparently the bearing housing had loosened up and as long as i was going in one direction it was fine but as soon as i moved backwards the entire pattern would shift from the backlash. similar to what your seeing.
Old 09-30-2009, 12:03 PM
Backlash is one problem I've banged my head on the table about as well, but I don't think it would cause this. I may be wrong, but backlash will only shift the entire coordinates of the piece. So if you're cutting in to uncut metal the location will be slightly off from where you want it, but for any operation you perform it will be the off by the same amount. That being said, I haven't entirely ruled it out as the culprit.
Old 09-30-2009, 12:13 PM
in this particular case i think it is backlash. i don't know how your approaching the hole, but if you come in with just an x move, you never preload the y screw, so before the move is made to make the circle the backlash has to be taken up. same goes for the reverse cut. i would adjust the gibs and check your ball screw and bearings on the wy axis.
Old 09-30-2009, 12:21 PM
littlerob's Avatar
With the blue pattern you are climb cutting, and with the red you are conventional milling. Could rigitity in the tool holder be the problem?
Old 09-30-2009, 12:22 PM
I'll look at it closer. The funny thing is I have more backlash on the x axis than the y axis so you'd think it would shift on the x axis as well, but only the y...
Old 09-30-2009, 12:25 PM
I've went down that path too and don't believe that's the cause. I've checked for motion/movement after I have the piece down and get none. The convention and climb mill is a good observation, and that's why I'm doing this. Conventional milling for a roughing pass and then climb milling for the finishing pass.
Old 09-30-2009, 12:30 PM
littlerob's Avatar
I'm with runner then I would say "backlash". Sorry couldn't be more help.
  #11   Ban this user!
Old 09-30-2009, 04:03 PM
mrainey is on a distinguished road
You only specify a Y coordinate one time. You're assuming that the tool is at Y2.5 at the start of each half-circle, but have you verified that? I'd try sticking Y2.5 in each circular move just as a test.
Software For Metalworking
http://closetolerancesoftware.com
  #12   Ban this user!
Old 09-30-2009, 05:21 PM
EPTech's Avatar
EPTech is on a distinguished road
I have had the same problem milling a rectangle. I had artifacts on the contour walls when milling with incremental depth. I do not know the deviation in your case but mine was severe (about 0.5mm). That's more then just backlash. In my case the four bolts that hold the housing of the lead-screw to the X-table were loose. Tightened them... problem solved.
using a counter gravy Parametric Programing 10 05-26-2012 06:05 AM
Testing 4 steppers,only turn clockwise msg Mach Software (ArtSoft software) 1 01-26-2008 02:10 AM
Clockwise only, XYZ- and +? lbrc Mach Software (ArtSoft software) 2 06-20-2007 10:25 PM
counter sensor problem on johnford vmc, need help wiredude CNC Machining Centers 0 05-10-2007 05:30 PM
counter cncsdr Haas Mills 2 11-08-2005 07:56 AM
