Old 09-28-2009, 11:20 PM
jGEE is on a distinguished road
Where to buy parts Jet JMD 18 drill/mill?
Hello guys,
My first post and need some help finding parts for a Jet JMD18 Drill/Mill. I was given the Mill and it's in nice/ok shape. I own a lathe but never done anything on a mill.
I'm taking it semi apart/cleaning it. There is no wear in the table screws or brass nuts. They are split nuts so i took up a couple of turns to tighten them a bit. The ways a fine no signs of any wear. I can't feel any play in the spindle but that's probably not a test. I was told it was mostly used as a drill press.
I need a table handwheel, a face plate, the handwheel for the spindle and a few other things. I would like factory replacement parts.
It took a while but the only place i found to buy parts is
Walter Meier. I placed an order but i don't think it went thru. I called they said they will let me know in 48 hrs if they got the order, sorta funky if you ask me. Is there someplace else to order factory parts, is this place legit??
thanks!! joe
Old 09-28-2009, 11:53 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Joe,
Walter Meier is the importer and direct source for Jet here in the USA.
If you decide to purchase the parts from a dealer, they will order them from "WMH Tool Group" Walter Meier.
http://www.jetwilton.com/us/manufact.../about_us.html
They are legit.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 09-29-2009, 12:26 AM
Thank you Mr Jeff.. that's where i ordered - i was just a little nervous, i feel a lot better.. i'll go by what you have posted in your by-line, lol.
My plans are to make small parts with mostly aluminum, maybe small parts out of some soft steel or stainless. Probably a 4" square of stock will make anything i will do.
What kind of holding device for my cutting tools? i see sets of R-8 collets, I see a R-8 holder and you just change the collets. Then some cutting tools are R-8 with changeable carbide tips. Should i get a set of R-8 collets and find a set of end mills? I'm sorta lost on what to do to get started.
The only tool that came with the mill was a 5/8" jacobs chuck.
Will a jacbos chuck hold a 5/8" end mill or will it just loosen and fall out and kill me?
I also need a vice to hold my work, any suggestions on "off shore" parts -limited budget. What general purpose vice do i need? I have been looking on e-bay. Lots of stuff for a mill and i am about to figure out some of it!
thanks for the help. joe
Old 09-29-2009, 12:54 AM
jalessi's Avatar
Post
Joe,
I would not suggest using a Jacobs chuck to hold a end mill.
R8 is very popular and they are relatively inexpensive.
Look for a used Kurt vise, they last for ever and are top shelf.
Jeff...
Old 09-29-2009, 08:28 PM
thanks for the help. I got my eye out for a Kurt -whew they are kinda pricy.. called back to today and had to resubmit my order.
thanks again
joe
feedback on a Z axis kit for a knee mill and mill drill extsuba Vertical Mill, Lathe Project Log 1 03-31-2009 06:06 PM
WTB- Enco / Rong-fu Mill-drill Parts mranthony Want To Buy...Need help! 0 01-15-2009 08:42 PM
(WTB) mill/drill balibalistic Canadian Club House 7 02-20-2008 05:17 PM
Drill holes with end mill or twist drill ? Argofanatic General Metalwork Discussion 15 12-29-2006 10:05 PM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
