Old 09-27-2009, 09:25 PM
joprinz is on a distinguished road
Question Can RC Brushless Motors be used as Spindle Motor ???
I have been trying to design a DIY Spindle for milling aluminum. I came across this DIY Spindle
The Designer is using Brushless Motor (used by RC Airplane hobbyists)
Motor Specs (from the Manufacturers Page)
Power 110 Brushless Outrunner Motor, 295Kv
Overview
The Power 110 is designed to deliver clean and quiet power equivalent to or surpassing the power of a 110-size 2-stroke glow engine for sport and scale airplanes weighing 9 to 15 pounds (4 to 6.8 kg), 3D airplanes up to 11 pounds (5 kg), or models requiring up to 2000 watts of power.
Key Features
* Equivalent to or surpassing the power of a 110-size 2-stroke glow engine for 9–15 lb (4–6.8 kg) airplanes
* Ideal for 3D airplanes up to 11 lb (5 kg)
* High-torque, direct-drive alternative to inrunner brushless motors
* Includes mount and mounting hardware
* High-quality construction with ball bearings and hardened 8mm steel shaft
* Includes two 12mm prop shaft adapters tapped out for 10–32 threads
* Ideal for models requiring up to 2000 watts of power
* External rotor design for better cooling
The motors are pretty compact and can do High RPMs. Also we could hook up an encoder to the shaft for RPM control. Everything looks promising but I am not sure about the CONTINUIOUS OPERATION CAPABILITY of these motors since most RC Planes only fly for around 15-20 mins.
  • I was wondering if such motors can be used as spindle motors?
  • If anyone has experience using these motors please share your experiences/Ideas.
  • Also please share your ideas on other suitable types of Motors for a DIY Milling spindle.
Thank You
Joe
Old 09-27-2009, 09:33 PM
Korellibopper is on a distinguished road
thats a very interesting question man they make a rc car brushless motor that put out 1hp i dont know how to control the speed control without the remote. Probably a reohstat would do. Oh email novak and ask them about duty cycle and tell them your end use. Theyll probably be able to tell you. being about to do the Horsepower calculation for the make tool diameter you intend to use would be great to know too. Let me knowwhat you find out.
later
Old 09-28-2009, 02:46 AM
eSilviu is on a distinguished road
Thumbs up
Thank You
Joe
1. Does it spin?
2. It has all the power do you need?
PS: Search for a "heli" controller. These ones try to keep rpm constant at load variations.
Old 09-28-2009, 10:59 AM
Originally Posted by eSilviu View Post
1. Does it spin?
Ofcourse it does spin...n its rated 2000Watts and can do around 10K rpm. I guess that should be sufficient for light milling work... But I do not know if these Outrunner type Brushless Motors are designed to work continuously for hours. Not to forget the fact that in a RC plane they have the propeller blowing air onto it inturn cooling it.
n Yes Heli Controller idea is good to keep the rpm constant...
The biggest Question is the Continuous Operation capability... Hope someone can share their experience working with these kind of motors...
Joe!
Old 09-28-2009, 02:38 PM
Joe!
- 2kW?! I want one too!
- I will try soon, with a 250-300W one. I need just the time to put all components together (I just mill PCB for now)
- there are fans (very efficient) that can be mounted on the outrunner
- what do you think that will fail?
copper wirings?! (I don't think so)
magnets?! (maybe glue that hold magnets in place, but I doubt)
bearings?! may-be, but it will fail because of dust that get there, not because of 10 hours of run.
Old 09-28-2009, 03:08 PM
Al_The_Man's Avatar
I have not used these motors, but I did check out some of the sites that show DIY versions, wind-your-own etc.
There appears to be two types, Inner rotor or outer rotor.
They did not appear to me to have suitable characteristics for variable speed and torque spindle or servo.
They appear to run extremely hot, 2kw in a very small frame!
Old 09-28-2009, 08:02 PM
Crawler374 is on a distinguished road
Usually your motors of that style is going to come, and only come in outrunner versions. Inrunners are for cars and buggys, the outrunners like that are for airplanes. Low torque high RPM. Check this place out, i get a lot of my RC stuff from them.
www.hobbypartz.com
Here is a large outrunner like the one in the video, and its cheeeeeep!
http://www.hobbypartz.com/mo1602brmo.html
and your speed controler
http://www.hobbypartz.com/vose80aopbre.html
I was wanting to do this on my DIY router, but i couldn't figure out how to turn the speed controller without a RC receiver and controller.
Old 09-29-2009, 12:55 AM
The one with inner rotor is named "inrunner” and the other "outrunner" (obvious why).
- Inrunners have no air circulations inside; usually are water cooled with a pipe of copper wounded around motor. This type of motors usually have high rpm - at 12V you may get 50-80k, but not more torque (it-s enough for PCB milling)
- Outrunners are true 3phase motors, driven with low voltage. The small controller always used to drive motor is a DC/3~ converter, with variable frequency. Output of the controller is not sinusoid, but square wave.
- Controller uses MOSFET transistors to drive motors, and this type of transistors are largely available in SMD capsule (40V/100A with 0.01ohm when ON). This is the reason controllers are so small.
- Motor presented, as any from this family has a really low windings resistance (0.3 ohm for example) so the heat dissipated is small.
For example: I use for milling a Proxon like tool, rated at max 150W. Let's suppose I will change the motor with an outrunner rated "2700W". I will still use just my 150W, so:
- with no load, motor will "eat" ~1,5A = 0.06W dissipated as heat = absolutely insignificant
- with 150W load: efficiency of the motor is >90% so it will dissipate heat... max 15W (150W from 25V means 6A => P_heat=36*0.03=1W !!!!)
Only one problem remains: to find a power source that can delivery energy as low voltage high current - only switching power supply can do this.
Old 09-29-2009, 01:06 AM
Motor is awesome, but the controller is not 100% compatible.
Look at the motor: "Cells Li-Po: 9-10" = 40V_max, and the controller: "Li-ion/Li-poly: 2-6" = 24V_max. So you will use motor at maximum half its power. (personally I think that it's enough even so)
-without controller (DC/3~ inverter) is impossible
-but as RC receiver search for a "servo tester" circuit (IC 555 as astabile). there are many circuits.
Old 09-29-2009, 05:59 AM
TOTALLYRC is on a distinguished road
An Astro Flight servo tester would work well in place of transmitter/receiver and has a knob for variable speed.
It should be enough to get started. Just plug it into the "servo" lead of the ESC. You may need an external 4.8v depending on your ESC. There are devices that will turn the knob via the CNC controller but I can remember who makes it right now.
I have several motors both inrunner and outrunner and will test when the time is available. I would make sure there is plenty of cooling if running the motor near its max power input. A watt meter will tell you what the power consumption is and could be left in the circuit while cutting to monitor it for quite awhile. My plan is to make a spindle and then drive the spindle with the brushless motor.
If you use a castle creations esc they have helicopter function built in and are easily accessible through the castle link.
Mike
  #11   Ban this user!
Old 09-29-2009, 06:00 AM
Usually you can throw more than 24v at a motor that size, you can run barely 24v on a standard 550-540 size motor which is like 1.5" in diameter. But here, I think that torque is needed a little more than RPM's. So amperage would be the key here.
  #12   Ban this user!
Old 09-29-2009, 06:03 AM
Mike
That is a Sweet idea! never thought of that....I suppose you can put a 20-24v power supply to the motor leads with the servo tester and see how it goes. I might try this in the future.
brushless DC motors for spindle drive bilinghm Benchtop Machines 14 04-28-2008 04:16 PM
High Speed Spindle for Taig - Brushless Motor? GammaWill Taig Mills & Lathes 14 03-29-2007 03:43 AM
Brushless spindle motor Yint General Electronics Discussion 0 03-20-2007 11:36 AM
brushless motor as spindle? limbo DIY-CNC Router Table Machines 24 03-02-2005 01:01 AM
