Old 09-26-2009, 12:03 PM
constantin is on a distinguished road
Unhappy run a Haas VMC without rotating spindle
Hi! I would like to scrape a linear pattern on a plate, with an insert, without rotating the spindle. I have a vertical milling CNC Haas VF-2
Is there a setting that will allow the machine to run without rotating the spindle? Thank you for your help.
Old 09-26-2009, 12:47 PM
Have you tried just orienting the spindle with M19? I do not know if you can then move the axes under feed without getting a spindle not turning alarm.
Old 09-26-2009, 02:19 PM
Smile many thanks
your idea was excellent Geof, with M19 my Haas moves with feed without rotating the spindle. Thanks a million
Old 10-07-2009, 04:18 AM
MCR-B II is on a distinguished road
Of course You do your job. But i think this machine for machining in rotational. Be sure not to damage spindle bearings
Old 02-16-2011, 10:06 AM
rschap1 is on a distinguished road
M19 direction?
Does anyone know how to set spindle direction when indexing using M19 on a Haas, CW versus CCW?
waiting on their "answer man currently"
Tags
haas, knurling, spindle orientation
Haas Spindle Air Supply rrbmachining Haas Mills 7 12-21-2008 10:38 PM
Haas TM-1 Spindle problem speedrider Haas Mills 6 07-11-2008 01:48 PM
HAAS vf1 spindle problem daleman Haas Mills 7 11-12-2007 11:02 AM
spindle not rotating tiwanags Commercial CNC Wood Routers 2 09-11-2007 07:49 AM
Just got a Haas VF1 with 30k spindle rhettmandel Haas Mills 4 01-21-2006 06:32 PM
