Old 09-21-2009, 08:46 PM
slade17 is on a distinguished road
Broken Tree mill - help diagnosing problem
The Tree mill in the student shop at my college broke a while ago, and it looks like it's up to me to fix it. Someone reported that 2/3 of the fuses on the mill blew. I used a voltmeter to check the voltage input and it seems to be fine. I turned off the breaker and checked for a short between any 2 of the 3 phase power inputs (or to ground) and there wasn't one. I replaced the fuses, turned on the power, and pressed the power button, but it didn't turn on. I then held the power button for a second or two and the box started smoking. Does anyone know what's going on here? My only thought is to pull the motor apart to see if something happened to it, but I don't want to do that unless it's absolutely necessary.
Diagnosing VF-0E way lube problem James K Haas Mills 12 09-29-2010 06:17 AM
tree 2uvr-c tree mill willcofab Tree 1 06-11-2009 01:40 PM
broken carbide end mill. ihavenofish General Metalwork Discussion 10 05-27-2009 06:46 PM
Tree mill 325 E-Stop problem HOSS Test Forum 0 12-02-2008 07:10 PM
Broken Mill help avsfan733 Bridgeport and Hardinge Mills 9 11-15-2004 11:17 AM
