Old 09-15-2009, 10:42 PM
kalawa is on a distinguished road
Mitsui Seiki HR5B
Hi all,
New to this forum and know next to bugger all about cnc and electronics. Been amazed though on reading some very inetresting and knowledgeable threads in this forum.
We have a 1985 Mitsui Seiki HR5B horizontal cnc center, fanuc 11M controlled that is giving us grief at the moment.Sequence of events
1. Spindle noise. Took out spindle and found encoder conpartment half full of oil. Cleaned it up, re-set encoder, noise persisted.
2. Took out spindle drive, air-cleaned and found the legs of 2 off blue colored resistors touching, separate them, re-fit and alas, noise gone.
3. Then when moving Y axis, this horrible screeching sound comes out of the motor. Z axis runs ok.
Would the removal of the spindle drive have anything to do with the behavioural change of the Y axis? If so (and even if not), I would appreciate all the help I can get for this anomaly.
Thanks in advance
Old 09-21-2009, 02:45 AM
axis overtravel
adding to problems in my last posting,the above machine y axis overtravelled and will not re-set to start the machine. There is a 2nd LS Remover button on the panel but does nothing. Now my priority has changed to getting this overtravel fixed first before fixing the axis noise as above.
All help will be highly appreciated.
problems with ATC on mitsui seiki saacengineering General Metal Working Machines 10 07-29-2010 03:53 AM
Need Help!- Mitsui Seiki with Fanuc OM control tano Fanuc 11 09-18-2009 03:29 AM
Need Help!- Mitsui Seiki VR-5A plzlaa Fanuc 0 08-11-2008 09:21 PM
Need Help!- Retention Knobs for Mitsui Seiki VR 3A barchdesigns CNC Tooling 0 07-07-2008 11:57 AM
Mitsui seiki VS3A ARIF AHMED General Metalwork Discussion 0 07-30-2007 12:33 AM
