Old 09-14-2009, 04:20 PM
PMF PMF is offline
PMF is on a distinguished road
Laser with rotary for tube cutting
Folks,
I hope that this is the right forum to ask this question. We cut tubing (2in to 1in SS) using a laser and a rotary fixture. The controller is an Anorad II. I am still new to using this type of setup. But when we cut the tubing the distance we specify to travel around the tubes circumference (spinning the collet) does not equal the true circumference of the tube. If I tell it to rotate the tube a distance of 6.28318 (circumference of 2" tube) it will rotate 360 plus 1/4" or so. I cannot figure how the machine is calculating the distance. The encoder has 100 lines of resolution, and is attached to a 90:1 gear box. Any ideas on why things are not adding up. I hope I have explained what is happening well enough.
Thank you very much for the help!!!
Old 09-15-2009, 03:56 AM
kawazuki is on a distinguished road
Maybe it needs internal circ. not external?
Old 09-15-2009, 09:14 AM
PMF PMF is offline
Circumference
Kawazuki,
Thank you for your reply. Unfortunately using the internal circumference does not work out either. I am at a bit of a loss.
Old 09-15-2009, 09:20 PM
youngjim is on a distinguished road
6.28 is approximately 2*pi radians, is it working on that?
Jim
No time to do it right, plenty of time to do it twice.
Old 09-16-2009, 09:55 AM
PMF PMF is offline
Radians
Hey Jim,
Thanks for the reply. I worked out the resolution of the rotary fixture in degrees and then converted to radians. It appears to be very close. So we are going to try it and see what happens. I agree with you that it is probably radians.
Thanks!
Old 09-16-2009, 12:57 PM
Piece of cake. Heh.
Jim
Using Laser Tube on a CNC emvali Laser Engraving & Cutting Machines 38 04-15-2009 11:56 AM
70w laser tube lamicron Laser Engraving & Cutting Machines 5 12-10-2008 08:19 AM
Laser Tube Help FlyGuy007 Laser Engraving & Cutting Machines 14 09-06-2008 02:50 PM
Is my laser tube ok? PaioX Laser Engraving & Cutting Machines 4 07-23-2007 03:34 AM
bad laser tube CNCadmin Laser Engraving & Cutting Machines 40 07-03-2007 10:23 PM
