Old 09-07-2009, 06:46 AM
ugpostguy is on a distinguished road
1983 vintage Toshiba Horizontal - 4 axis
Hi all
I've been asked to help out with a vintage Tosh BMC 6C. It has 4 axes and the user wants to start programming the B axis for 3 + 1 milling. I'm looking for a way to shift the CSYS when the part is rotated. In what's left of the
manual I found G11 - coordinate system translation and G10 - cancel G11. As near as I can figure, it works like G68 (Fanuc, Mazak) and G7 (Heidenhain). The problem is that I can't find a single programming example to help with the syntax. I'm not learning much from MDI at the machine and web searches have turned up nothing.
Does anyone know the procedure for using this function or any other way to get there on the old Tosh?
Thanks much,
George
HS1 horizontal mill with auxillary axis alarm teal854t Haas Mills 2 04-18-2009 12:47 PM
Disabling A-axis, horizontal mill teal854t Haas Mills 0 03-23-2009 06:56 PM
Problem- axis causes horizontal streaks in display stoughto LinuxCNC (formerly EMC2) 8 03-19-2009 11:12 AM
Toshiba Horizontal information jp41558 General Metal Working Machines 0 12-03-2007 07:18 AM
B axis for horizontal mill OM nabil_elbadri Fanuc 3 11-16-2007 06:19 PM
