Old 06-11-2003, 02:42 PM
Ben Ben is offline
Ben is on a distinguished road
Roughing end mills for aluminum?
can anyone recommend a good roughing end mill for aluminum? i have been looking at the Minicut roughing/finishing end mills that Rutland sells. it says they're specifically for aluminum. has anyone used one of these before? are they worth the money?
thanks,
ben
Old 06-11-2003, 03:14 PM
Rekd's Avatar
Rekd is on a distinguished road
Re: Roughing end mills for aluminum?
thanks,
ben
Hi, Ben.
Like anything else, it will depend on a number of factors...
[list=1][*]Type of Alum?[*]Machine stability/speed/feed[*]fixture stability[*]type of roughing, contour, pocket, surf etc[*]depth you need[/list=1]
'Rekd teh more data please
Old 06-11-2003, 03:27 PM
Ben Ben is offline
hi rekd. i'm a novice, and i don't quite know how to answer your questions. i think i'll be working mostly with 6061 Al. i have a tiny sherline 5400 mill, which i use to make parts for my RC helicopters. i just need a good general purpose roughing end mill to make my work go a little faster.
Old 06-11-2003, 03:51 PM
E-Stop is on a distinguished road
Ben--
I use the International Minicut on alot of the aluminum jobs we run. I use 1/2", 5/8" and 1" diameters. The ones with the polished flutes cost a bit more but is worth it. They evacuate the chips a bit better and don't load up. I'm not sure how much you can pull with your Sherline but these things will really hog out the material. For instance, I run the 1/2" cutter at 7640rpm and 85 inches per minute. Full width of cutter thru 3/4" aluminum and it just eats it up.
One cutter that I like better is the SGS Ski-Carb. They are a little more expensive but I have run them at 10,000 rpms at 200 inchs and it cuts like butter. Regrinds are no good unless you let SGS do it because of their special geometry.
Old 06-11-2003, 03:58 PM
Ben Ben is offline
thanks, e-stop. i think i'll try one of the ones with the polished flutes.
Old 06-11-2003, 04:07 PM
Rekd's Avatar
Sounds like many of the standard mills will work. You might consider the minicuts if the price is good. Dont' spend top dollar for performance EM's if your machine/applications don't warrent it. (For hobby stuff, the standard tooling will work just fine)
'Rekd teh All this talk about homemade routers and mills makes me wanna makes me one.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 06-11-2003, 05:04 PM
CAMmando's Avatar
CAMmando is on a distinguished road
Rekd,
I been thinkin teh same thing.
Have you checked out some of the pics in the home made router threads ?
looks like fun.
Wee aim to please ... You aim to ... PLEASE.
G-Code to DXF WayneHill OpenSource Software 189 01-30-2012 11:15 AM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 02:24 PM
Pro/manufacture -number of decimal places arc events dsergison Post Processor Files 4 05-27-2005 01:50 PM
End Mills and Sharpening Robin General Metalwork Discussion 0 04-08-2005 09:33 PM
End mill's? you ain't seen nothing yet Ken_Shea CNCzone Club House 7 09-01-2004 11:13 PM
