Old 09-04-2009, 12:49 PM
Allen123's Avatar
Allen123 is on a distinguished road
Buying CNC MILL
I am looking at buying a low cost cnc mill. I have thought about some of the knee mills from southwestern industries & the others. I am just not sure if I want to get a new machine used machine.
$17,000
* Factory-integrated package.
* Two-axis CNC, three-axis DRO.
* Easy to use - train in the morning, make parts in the afternoon.
* All the essential CNC functions
* Quality knee mill iron, precision CP 7207 spindle bearings and a chromed hardened and ground quill.
* Precision ballscrews in the table and saddle.
TRAK KE EMX Machine Specifications
* ProtoTRAK Control model -EMX
* Table Size-50" X 10"
* Table Travel -31"
* Saddle Travel-15.5"
* Knee Travel:-13.5"
* Ram Travel-21"
* Maximum Quill Travel-5"
* Quill Diameter-3.375"
* Spindle Taper-R8
* Spindle Speed Range -70-4200 RPM
* Head Tilt-45° forward and back, 90° left and right
* Quill feeds per rev-0.0015”, 0.003”, 0.006”
* Spindle Motor- vari-speed-3 HP
* Power Requirement Control-110V; 1P; 8A
* Power Requirements Machine -220/440V; 3P; 8.5/4.3A
* Maximum Weight on Table-850 lbs
* Machine Weight:-2820 lbs
* Machine dims: l x w x h-71" x 59" x 87"
* Maximum rapid feed-100 IPM
* Way surface type-Dovetail: X, Y, Z
* Precision 7207 CP4 Spindle bearings
* Chrome hardened and ground quill
* Slide ways are Turcite coated
* Wide way surfaces are hardened and ground
Available Options/Accessories
* Remote Stop/Go Switch
* Power drawbar
* Halogen work lamp
* Chip pan
* Knee power feed
* Coolant pump
* Table guard
* Vise
* USB memory stick
* Auto lube pump
* Spray coolant
The Trak machines seem to have good conversational software but I already know CAD CAM and can program with G-code. So really any machine that reads g-code would work for me.
I found some information on a off brand knee mill or bed mill that costs $2000 less than the trak mill but I am not sure if it's worth the money.
Here are some pictures:
Some Specs:
Linear guide ways
Precision ball screws
Work Table: 10” x 42”
Table T-Slots (5)15mm
2HP 6,000 VFD Spindle
ER-32 Collet
Travel X 22” Y10” Z18”
Rapid Traverse
Stepper 250 IPM
Servo 650 IPM*
Machine Foot Print 48”R-L, 34” F-B, 7'Tall
Shipping Weight 2,365 lbs
Power Requirements 220 VAC/3/60
Single phase *
Integrated 17” Touch Scree 150G HDD Dual Core 1.8 CUPs
CD/DVD Player (5) USB Ports Speakers Ball mouse Ethernet Keyboard
Cycle start, Feed hold, Emergency Stop, Reset, System enable Misc, operation
Lubrication system
Customized Mach 3 CNC Controller Interface
EIA ( Standard G-M Code Programming)
Work offsets, Tool length Offsets, Cutter Compensation
G01 G02 G03 Linear interpolation , CW, CCW Helical interpolation
G04 Dwell, 3D Plane Select G17,G18, G19Inch / Millimeter
G28 Reference Home G31 Probing G40-42 Tool Compensation
G54 Height Offsets G50 Scale factor reset G53 Machine Coordinates
G61 High Speed Machining,G64 Exact stop, G68 Coordinate system rotation G90 G91 ABS INC
M98 / M99 Sub Routines
When I looked at the southwestern machines and alike. They seemed to have a little more travel, and "industrial" controls.
This off brand machine has a mach 3 touch screen. Which looks cool but is it practical? Is mach 3 just as good as an acu-right or Trak controller or a like?
The power requirements I can work with, and the fact that is a smaller more compact unit is appealing to me. But how good of a machine is it?
How can you tell by specs or pictures if the machine is worth it's salt?
I keep going back and forth on buying a used machine. But I am worried about buying someone's red headed step child if you know what I mean.
If I do get an older controller / machine the memory and parts? limited or hard to get?
Any recommendations you might have would be very helpful.
Old 09-04-2009, 02:24 PM
Allen123's Avatar
Video on acer
http://www.aceronline.net/videoPlay2.php?id=13
This is a neat little video on a Acer Mill
Old 01-05-2010, 10:29 AM
*Registered User*
dullfig is on a distinguished road
What brand is that machine? you gave a lot of info on it, but no brand
Dan
Old 01-06-2010, 01:02 AM
vigilante212 is on a distinguished road
Prototrak makes a very nice machine, I used to work on one for about a year. They have a nice simple conversational control. I also worked on a prototrak that looked almost exactly like that lower picture. It was a more rigid machine a bit more robust more accurate, but the interface was a bit more complicated. Out of the 2 i would get a prototrak that looked like the bottom machine.
Old 01-06-2010, 09:48 PM
tizm is on a distinguished road
The picture on bottom of page looks very similar to the tormach machine! ive heard good things about them! but with those types of machines,your always gonna deal with the rigidity!!
Old 01-07-2010, 10:21 AM
metlcutr55 is on a distinguished road
bought mine from these folks 12 yr ago, it has been a good machine, full 3 axis z knee driven, close to same money. run nearly daily for 12 yrs. if these interest you, pm me a phone#, or ill pm mine, id be glad to yak a bit.
http://www.cncauto.com/
Old 01-07-2010, 02:23 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Sure you know G-code.
So do I.
The conversational control just completely rocks.
You can program a pocket and be making chips in less than 2 minutes. Can't do that with g-code.
Go for the ProtoTrak
FWIW I love the Fagor 8055 control, just in case you come across a machine with one.
www.integratedmechanical.ca
Buying CNC mill, any advice? Haeusser General Metal Working Machines 7 09-20-2007 10:06 AM
Buying a used mill JOE65 Benchtop Machines 1 05-07-2005 11:54 PM
Buying a new mill sundy58 General Metalwork Discussion 0 04-11-2005 10:34 AM
Buying my first CNC mill sundy58 Bridgeport and Hardinge Mills 9 01-28-2005 10:08 PM
Buying my first cnc mill. Please help! touser General Metal Working Machines 15 10-31-2003 09:58 PM
