Old 09-03-2009, 09:32 PM
applebuilder is on a distinguished road
What's the cost of milling small stock?
Hey new kid on the block wants to know what it would cost to mill 1"x3"x30" metal stock for straightness and square. Basically it's a straight edge so I'm looking for decent tolerances. Are there any other maching methods other than CNC I should look at? Thanks.
Old 09-03-2009, 09:35 PM
Might as well figure out what the stock would cost as well. I'm guessing stainless steel would be good but I know nothing of metal so feel free to suggest.
Old 09-04-2009, 08:34 AM
kling8 is on a distinguished road
you should be able to get that part fairly cheap, I would go to a smaller shop, and get a bid, or a friend and a favor may do the trick. stainless is a lot more money, and more of a pain to machine, depending on your application I would try to stay away from stainless. Just my opinion.
Old 09-04-2009, 09:56 AM
Don't forget the cost of stress relieving. This will "spring" after machining, you may have to relieve it more than once.
Dick Z
DZASTR
Old 09-04-2009, 08:59 PM
Thanks for the tips. What kind of metal would you suggest? I don't need anything fancy, whatever gets the job done. Unfortunately I don't have any metal working friends so with the milling, stress relieving and whatever else what's the rough price tag I'm looking at? Thanks.
Old 09-05-2009, 01:43 AM
jdr jdr is offline
jdr is on a distinguished road
You might want to try Starrett Precision Ground Flat Stock.
Comes in 1" x 3" x 36" pieces. They also sell 18" long sizes.
Several choices of steels.
Old 09-05-2009, 06:58 PM
Thanks, I'll take a look.
Old 09-05-2009, 07:46 PM
warrenb is on a distinguished road
Get this off the shelf. There's no reason to have this machined. Like JDR stated you can buy this stuff.
If it's not cuper critical you can get extruded aluminum
Old 09-12-2009, 10:51 AM
PixMan is on a distinguished road
For that matter, why not just buy a good Starrett straight edge?
http://www.starrett.com/download/308_p340_342.pdf
Problem- How to setup, 6x2.5x.5 stock in Milling Machine Musick7 Teachers Hang out 5 04-10-2009 09:56 PM
Best way to organize and load sheet stock in a small shop? douglasco CNC Plasma and Waterjet Machines 2 10-31-2008 09:19 PM
Newbie- Create new milling stock Micky15044 BobCad-Cam 5 10-14-2008 05:15 AM
Low cost machine for PCBs, engraving, and small parts jdlinke Want To Buy...Need help! 2 01-27-2008 12:45 PM
Need suggestions on how to cut ALOT of small parts out of rod stock Anokiernan Benchtop Machines 14 11-26-2007 01:02 AM
