Old 09-01-2009, 08:09 PM
TSquared is on a distinguished road
Drill Press Quill Play - Help!
Just purchased a Harbor Freight #39955 20" Production Drill Press. Had a 20% off coupon, so couldn't resist the price. Checking the quill play pushing front to back I get .006 (.003 forward and .003 back) and get .003 side to side.
Is this excessive. I can't for the life of me figure out how to take out the play. Looking at the exploded view, I don't see a split casing on this model with any type of screw to tighten it up. Any suggestions anyone?
Runout is ok at .002. The quill play is bothering the heck out of me. Am I worrying about nothing? Thanks.
Terry
Old 09-02-2009, 03:52 PM
hoghead is on a distinguished road
You are probably worried about nothing. Those numbers are about right for Harbor Freight quality. There will not be any way to adjust the quill play, it is what it is. It should work just fine. If it doesn’t your going to need to step up to a more expensive and higher quality unit. Even a good Clausing will have .002”-.003” shake on the quill.
I have repaired loose quills quite a few times but never on a Harbor Freight unit. The cost would be way too high. The only good way to do the repair is to remove the quill and hone the bore straight and round, then grind the OD of the quill, chrome plate and regrind the OD of the quill to match the bore. If you did all that work and didn’t install high precision bearings you would have wasted your time and money.
Greg Rockwood
Machine tool repair and rebuilding in Los Angeles CA www.Studwellengineering.com
Old 09-03-2009, 08:27 AM
kling8 is on a distinguished road
I agree you are worried about nothing, I think you are always going to have some run out with a drill press. Depending on your tolerances and application, if you have really tight tolerances I would use a different machine, bridgeport would be one.
Old 09-03-2009, 06:37 PM
Thanks for the detailed reply. Maybe a home milling machine next?!
Terry
Old 09-03-2009, 09:13 PM
Mike Nash is on a distinguished road
I bought my drill press (Guardian Power) around 1980-81 out of the trunk of a car at a flea market. It too had more quill slop than I cared for. I finally crammed a piece (pieces?) of HDPE between the quill and the casting (inside the head) and have been happy with it ever since. I don't remember any of the details about how I went about it, but it was very low tech. And it worked!
Old 10-22-2009, 12:56 AM
emperor_wu is on a distinguished road
I have a similarly cheap drill press (traded a laptop computer that I got for $30 for the drill press) with gobs of play between the quill and head casting. I'd love to hear more about Terry's HDPE fix. I was considering putting in three long thing strips of HDPE running the vertical length of the cast sleeve -- each one third of the way around the circumference. Has anyone successfully shimmed their quill in the head of the drill press? If so, how'd you do it?
Drill Press. what do I need to know. zerodegreec General Metal Working Machines 15 12-10-2008 08:07 PM
Need Help!- HELP WITH PROGRAMMING QUILL TO PECK DRILL morowat G-Code Programing 4 06-21-2008 04:32 PM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Sieg X3 as a drill press.... good quill? InspirationTool Benchtop Machines 0 08-07-2006 04:25 PM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
