Old 08-31-2009, 04:49 PM
bigalexe is on a distinguished road
Buy entire drill press or just motor?
I currently do not own a milling machine of my own. So I picked up a Walker-Turner (ancient relic) drill press with an XY Table in mediocre condition for $100 at an estate auction. The drill press does NOT have a motor, I'm assuming the original motor burned up and the guy never replaced it. The rest of the machine is in surprisingly reasonable condition for being an ancient relic.
My question is whether I should buy an entire new metalworking drill press (available for like $150 via harbor freight) and use the XY Table with it thus junking the rest of the machine; or buy a motor and controller, wire it myself, and then sit back proud I rekindled the life of an old machine and am now using something that should be in a museum.
Approach 1 has the pro of less work, and the caveat that I overpaid for essentially a used XY Table. Approach 2 has the pro of self-satisfaction and the caveat of much more work for not much less money and lack of a warranty.
Stuff i can use: AutoCAD 2010, AutoCAD Inventor 2010, Solidworks 2009, MasterCAM X2/X4, CNC's FADAL, and Hurco 3-axis CNC Mill
Old 08-31-2009, 05:30 PM
Al_The_Man's Avatar
I believe you would find a drill press traditionally does not make a good milling machine, not enough rigidity.
But if you want to resurrect the drill press, you could either find a used 3 phase motor and put a VFD on, or locate a suitable DC motor and pick up one of the KB/Baldor SCR controls off ebay.
Old 08-31-2009, 05:37 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Not to mention that if it dosen't have a draw bar of some sort for the tool holder, it will not stay lodged in place when side milling = destroyed part and waste of time and material.
X/Y tables on drill presses are for positioning purposes only.
Paul
Old 08-31-2009, 06:42 PM
hoghead is on a distinguished road
Al & Paul said it all, a drill press does not make a very good mill. The spindle bearings are designed for thrust not side load. The body of the drill press, the head and the spindle are not rigid enough to do even the lightest of milling. That being said Walker-Turner made some of the best drill presses. There are no parts for them if anything breaks. I get a couple of calls a year from people looking for clock springs (quill return spring) and I can’t help them. Don’t even think about the Harbor Freight unit. I don’t have anything against Harbor Freight I buy some of there stuff but there drill press will not be 1/10 the drill press that the Walker-Turner is.
Greg Rockwood
Machine tool repair and rebuilding in Los Angeles CA www.Studwellengineering.com
Old 08-31-2009, 07:00 PM
So the suggestion is to resurrect the drill press with a new motor, and don't use it for milling.
Well I guess I'll consider this a $100 drill press purchase with an additional $100 (or whatever motor+setup costs) lesson in "look before you leap."
reversing a ac drill press motor? ZipSnipe General Electronics Discussion 10 05-25-2009 10:40 PM
drill press mod tbenefi33 Wood Lathes / Mills 1 02-24-2009 04:49 AM
Drill Press. what do I need to know. zerodegreec General Metal Working Machines 15 12-10-2008 08:07 PM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
