Old 08-23-2009, 05:01 PM
UWP_Wes is on a distinguished road
Help with Dyna Myte 2800 Conversion
Hello everyone.
I am in the process of converting an Dyna Myte 2800 to a PC based control. However, I have run into a stumbling block with controlling the spindle speed.
Some background on this machine. The spindle motor is a .75kW brush-less DC motor. The motor is powered by a servo amplifier made by Servo Dynamics. This amplifier is in turn controlled by a digital to analog converter board. Spindle speed is set using a potentiometer on the control panel and an encoder on the spindle displays the speed in an LCD. The stock motor is not reversible.
While probing inside the control cabinet with a multi-meter, I crossed the probes and burned up a capacitor and a small integrated circuit in the D/A conversion board. I now have no spindle control.
I am using the CNC4PC C11G breakout board. This board has a 0-10V variable output to control a VFD. I was hoping to substitute the existing spindle speed potentiometer with the output from the breakout board. I still think this is the correct method.
The potentiometer is connected to the D/A converter board which is now not working. I cannot operate the spindle currently. I am trying to understand how the D/A works and if it is necessary to get the spindle working. I should be able to replicate the input needed to get the spindle amplifier working. I do not have a wiring diagram for the spindle amp.
I have attached the wiring diagram from the machine manual. I also have included the current connections to the servo amp (bottom of the page). I am hoping that I can eliminate the D/A board and connect up directly to the amp because I doubt a replacement D/A board is available. I am not sure how to do this without causing further damage.
I can't figure out if the "speed pulse" wire or the "VO" wire are the speed control signal. The D/A board also has an input from an encoder on the spindle, but I have no idea how it uses it
I appreciate any help anyone could give me with this issue.
ID:	87206   Click image for larger version
Name:	Mill Board 001.jpg‎
ID:	87207   Click image for larger version
Name:	Mill Board 003.jpg‎
ID:	87208   Click image for larger version
Old 08-23-2009, 05:57 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
UWP_Wes,
What is the model number of the Servo Dynamics amp?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 08-23-2009, 06:13 PM
Sorry, the amp (and motor) is an Electro-craft.
Model - 170V
Serial # - H000993
Type - BRU-50
Part # - 9090-0541
Old 08-23-2009, 06:35 PM
jalessi's Avatar
Post
Are the connections marked on the servo amp?
Can you post a picture?
Old 08-23-2009, 07:13 PM
First pic is the control cabinet as a whole. Second is the amp. You can see there is no cover (maybe for better cooling?). The connections at the bottom correspond the the last diagram in my first post.
Name:	Mill Board 004.jpg‎
ID:	87219   Click image for larger version
Name:	Mill Board 005.jpg‎
Old 08-23-2009, 11:02 PM
jalessi's Avatar
Question
I cant tell which connections on the amp are the -10 +10
Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos ckm Knee Vertical Mills 190 02-18-2012 12:42 AM
Newbie- Dyna Myte DM2400 l5c2c7 Benchtop Machines 14 10-31-2010 08:50 AM
looking for a Dyna Myte DM2400 rcm Want To Buy...Need help! 3 05-15-2009 12:58 PM
Dyna 2800 Mill v8_dave Benchtop Machines 9 10-13-2007 12:07 PM
dyna 2800 dimension ataxy Benchtop Machines 0 10-21-2006 04:40 PM
