Old 08-20-2009, 06:39 PM
zaebis is on a distinguished road
Tapered holes?
I will soon need to open a good number of tapered holes on the mill 0.2-1.5" in diameter with a slight taper and as deep as 1". Gotta have smooth walls and be fairly accurate. Aluminum 6061. How?
Old 08-20-2009, 07:09 PM
OKUMAN's Avatar
OKUMAN is on a distinguished road
You should try a tappered EM.
Old 08-20-2009, 07:11 PM
Trent Steel is on a distinguished road
Yes, tapered endmill with circular interpolation is the fastest way on a 3-axis machine.
Old 08-21-2009, 07:06 AM
Superman's Avatar
Superman is on a distinguished road
Yes, rough with a tapered endmill
if finishing with the same sort of tool and it's not good, try heading for a tapered reamer ( reverse helix for smooth walls, size and taper will be consistant )
Hole Comes out Tapered HELP. Cartierusm General Metalwork Discussion 21 07-12-2009 08:09 AM
Tapered ID Threads mkimco Cincinnati CNC 0 03-19-2009 02:54 PM
Tapered Face jrrdw Mini Lathe 9 11-12-2007 05:24 PM
tapered hole dshowald Milltronics 5 05-01-2007 11:19 AM
Tapered gib chevdrgtrk General Metal Working Machines 4 11-28-2006 01:56 AM
