Old 03-01-2005, 12:31 PM
senor J. is on a distinguished road
Air Cooling?
hi I have a round column mill drill and wondering if high pressure air would be a sufficient cooler/chip remover. I'm not real excited about mist oils and flood coolant although one may have to do what one has to do. Is there any experience out there using a constant stream of high pressure air with no oil mists?
Old 03-09-2005, 04:27 AM
UKRobotics is on a distinguished road
Nice idea, unfortunatly I dont have enough experience in the field to give any advice of my own. Anyone else know if this would work ?
Dom
http://www.ukrobotics.com/projects
Old 03-14-2005, 08:05 PM
Mcgyver is on a distinguished road
I occasionally use air, especially when side milling with an end mill to clear chips. convention would say no air around a machine because it will blow crap into places you don't want it. That’s probably a good rule if you're managing people and have to have some rules, but for our home shops if we're carefull, don't indiscriminately blast everything and use low pressure (just enough shoe the chips away) directed at the cut, i think we can break that rule for clean materials such as cr steel, aluminum etc. I wouldn't do it with hr or cast iron however.
This technique will cool and clear chips but will not lubricate. imo you are better with a hand atomizer (windex bottle) filled with 40:1 cool tool or such (something with no health or odor issues). I end up with a noticeably better finish.
Shop air advice needed Swede General Metal Working Machines 26 12-10-2009 02:58 PM
Vortex air cooling kong General Metal Working Machines 10 10-08-2008 01:55 PM
El cheap air drier traveler CNC Plasma and Waterjet Machines 2 02-19-2005 08:21 PM
Is there any cooling liquid homemade formula? jlagran he General Metalwork Discussion 3 12-14-2004 09:33 AM
air chucks I.C.O.N. General Metalwork Discussion 2 03-03-2004 05:39 AM
