Old 08-17-2009, 04:41 PM
pyro77 is on a distinguished road
Amada 357 Queen with Fanuc 18P: C-Axis will not return to 0
Our company just bought a used Amada 357 Queen turret press with a Fanuc 18P control. I'm trying to write programs that will use a wheel tool in the first auto-index station and then change to a punch tool in the other auto-index station. The problem I have is that after cutting several arcs with the wheel tool, the program locks up on me. There is no alarm, it just stops at the block of code that tells the turret to change tool stations. It does this in several different programs I've tried. Each time, I noticed that the C-Axis is at 359.99 degrees, or something similar. So, the C-Axis is not returning to 0 like it should and that locks up the program. I can re-reference the machine and start over, but I can't get past this problem.
One individual I've consulted with said they have seen this before and they believe there is a rounding problem with the way the Fanuc 18P that causes this. Has anyone else had this problem? Does anyone know how to work around it? I've included an example of one of the programs that cuts arcs and then locks up when I want to use a punch tool.
Thanks!
O0565
(T220 ROLLING SHEAR KEYED 0.0)
(T256 OBROUND 1.0 X 0.312 KEYED 270.0)
G92X72.Y50.
G06A0.051B2
G90
M692
M561
M690
M693
X63.968Y25.341T220C200.
G172
G03Y46.954I-3.933J10.806F500.
G170
M692
M561
M693
G00X56.102Y25.341C160.
G171
G02Y46.954I3.933J10.806
G170
M692
M561
M693
G00X40.218Y25.341C200.
G172
G170
M692
M561
M693
G00X32.352Y25.341C160.
G171
G170
M692
M561
M693
G00X16.433Y25.381C200.
G172
G03Y46.994I-3.933J10.806
G170
M692
M561
M693
G00X8.567Y25.381C160.
G171
G02Y46.994I3.933J10.806
G170
M692
M561
M693
G00X63.968Y2.966C200.
G172
G03Y24.579I-3.933J10.806
G170
M692
M561
M693
G00X56.102Y2.966C160.
G171
G02Y24.579I3.933J10.806
G170
M692
M561
M693
G00X40.218Y2.966C200.
G172
G170
M692
M561
M693
G00X32.352Y2.966C160.
G171
G170
M692
M561
M693
G00X16.468Y2.966C200.
G172
G170
M692
M561
M693
G00X8.602Y2.966C160.
G171
G170
M692
G00
M500
M691
G72X54.688Y46.96
G66I10.693J0P-1.Q-0.313D0T256C270.(OBROUND 1.0 X 0.312) (<--This is the point where the program locks up because the C-Axis will not return to 0)
G72X30.938Y46.96
G66I10.693J0P-1.Q-0.313D0C270.
G72X7.153Y47.
G72X54.688Y25.648
G72X30.938Y25.648
G72X7.153Y25.688
G72X54.688Y24.585
G72X30.938Y24.585
G72X7.188Y24.585
G70X55.188Y15.
G72X54.688Y3.273
G70X31.438Y15.
G72X30.938Y3.273
G70X7.688Y15.
G72X7.188Y3.273
G70X60.Y24.
G27X48.
M692
M561
M690
M693
X111.468Y25.341T220C200.
G172
G170
M692
M561
M693
G00X103.602Y25.341C160.
G171
G170
M692
M561
M693
G00X87.718Y25.341C200.
G172
G170
M692
M561
M693
G00X79.852Y25.341C160.
G171
G170
M692
M561
M693
G00X111.468Y2.966C200.
G172
G170
M692
M561
M693
G00X103.602Y2.966C160.
G171
G170
M692
M561
M693
G00X87.718Y2.966C200.
G172
G170
M692
M561
M693
G00X79.852Y2.966C160.
G171
M692
G170
G00
M500
M691
G72X102.188Y46.96
G72X78.438Y46.96
G72X102.188Y25.648
G72X78.438Y25.648
G72X102.188Y24.585
G72X78.438Y24.585
G70X102.688Y15.
G72X102.188Y3.273
G70X78.938Y15.
G72X78.438Y3.273
G70X60.Y24.74
G27X-48.
M692
G50
Old 08-21-2009, 11:18 AM
Independent CNC is on a distinguished road
Post
Are you using programming software that will generate the correct code for this tool? If this is a Wilson wheel tool you may want to contact them and have them take a look at your code. Sounds like your missing a code.
Independent CNC Programmer
www.independentcnc.com
My mission is to share CNC programming innovations for a lifetime.
Old 08-25-2009, 03:36 PM
Since I've posted this I've talked to a couple people at Wilson (yes, it is a Wilson wheel) and 3 people at Amada. Wilson did not have a solution. Technically the code is right, but Amada admitted that this is a known problem with the Fanuc 18P control. I've been dialoging with one of the product engineers from Amada and this was one of the responses I received:
"There is not going to be a simple solution to your problem. A control update is not possible. I want to play around with the starting/ending angle on your part to see how this affects the A.I. accumulation error. " He is looking into a work around for me, but I'm not feeling very hopeful.
So, I've given up on a fix, but I'm still hoping to find a better work around. I can run a sheet twice with 2 separate programs, but that's going to really slow down production as well as make using the auto loader much more difficult. I wish there was a way to re-reference the turret mid program. Any ideas?
Old 10-15-2009, 03:01 AM
Tonex is on a distinguished road
You can try to add a line of code that is with the wheel tool before the tool change.
C0.0 / or C0.1
(the index station when do tool change work better in one direction)
(not always the same))
you can also try to use G70 at the same place
Old 05-11-2010, 03:20 PM
MARIUS MB is on a distinguished road
Hi people i see that u stop at ;O0565
G92X72.Y50.
G06A0.051B2
G90
M692
M561
M690
M693
G172
G170
G170 Digital measuring signals; block transfer with hard stop
G171 Digital measuring signals; block transfer without hard stop
G172 Digital measuring signals; block transfer with smooth stop
. What i see that probible this angle C-Axis at 359.99 degrees, not posible physicly maby u can start at another side of sheet it some times helps in some of situation. But progrm stoped at G170...
G03; ILEGALL ENDPOINT ?????
OK ! I found your mistake !!!
U make one very small mistake, that couse u all programm run.
Tags
amada 357 queen, c-axis, fanuc 18-p, return to 0
PROBLEM WITH FANUC 6M on Amada Coma cristalex_it_sr Fanuc 13 12-01-2011 03:35 PM
Pega 344 Amada Fanuc 6M electrical diagram nguyenthanhthi Fanuc 8 10-21-2011 08:31 AM
Need Help!- Amada Pega 244 w/ Fanuc 6m B controller memory replacement MetalForce Fanuc 10 08-10-2011 04:14 PM
Fanuc 4th axis zero return question drgbt Fanuc 5 01-17-2008 03:09 AM
Amada Fanuc 0L problem laser rick_7037 Fanuc 7 12-16-2006 02:48 PM
