Old 08-16-2009, 09:01 PM
bbeide is on a distinguished road
handwheels controlling motors?
Hello, I am looking for a hobby/light industrial cnc mill. I have read many of the posts decribing various choices to try to educate myself. One post decribed a cnc machine that could be controlled "manually" by using the handwheels to control the motors......is this normal?.....what machines use this method?.....does it work well?
THanks ben
Old 08-17-2009, 07:07 AM
PixMan is on a distinguished road
I don't know how the home-built machines have been doing it, but the nicest setup I'd seen to date was on a Deckel FP2CNC machine. When you pushed the handles in to engage the face spline (don't know what it's really called), the handles hit a switch that killed power to the axis servos and put the axis in manual mode.
Being on ball screws though, you had to be sure to put a little drag on the binder levers or you could risk having the axis get sucked right into a tool.
Old 08-18-2009, 06:11 AM
The one I read about basically had the 2 handwheels connected to the computer.....I doubt if there was a physical connecton to the table.
Old 08-18-2009, 11:03 AM
MPG's? Manual Pulse Generators Deckel used (uses) them as well. I didn't tell the guys who refused to run NC machines about them. They thought they were operating really smooth manual machines with digital readout's.
I think they are used on most machines now in manual mode (MDI). Select axis, increment and start cranking.
Dick Z
DZASTR
Micronor Handwheels DrStein99 General Electronics Discussion 1 06-06-2008 11:59 AM
MPG HANDWHEELS jholland1 AjaxCNC Control Products 4 04-19-2008 08:38 PM
Removing Proxxon MF70 handwheels?! Dongle Benchtop Machines 3 06-05-2006 02:18 PM
Help with controlling CNC! Kammo1 Stepper Motors and Drives 2 06-11-2005 02:54 PM
Seeking Electronic Handwheels for CNC conversion. ESjaavik General Electronics Discussion 1 07-10-2004 04:03 PM
