Old 08-16-2009, 07:56 PM
Area33 is on a distinguished road
CNC Machine Advice
Hello, I am new to cnczone and I hope this is the correct place to be asking this.
I started on a Smithy Midas 1220 manual mill/drill/lathe a few years ago, and have started a small business. I want to get away from contracting my parts out to other companies and want to machine my own.
I don't know a whole lot about CNC machine brands im looking for advice:
Mill:
-Capable of producing several hundred parts holding pretty tight tolerances, minimum 0.001"
-Has a bed that is at least 12"x8" in the XY plane
-Common Tooling
- $10,000 - $15,000 price range ready to run
Lathe:
-Hundreds of parts at 0.001"
-Somewhere around 30" between centers and 8" minimum Swing over Bed
-Common Tooling
Im going to start some more research, I just wanted to see if there is any recommendations, also both will be machining aluminum 90 percent of the time
Old 08-17-2009, 01:12 AM
awerby is on a distinguished road
[QUOTE=Area33;653237]Hello, I am new to cnczone and I hope this is the correct place to be asking this.
Mill:
-Common Tooling
[Take a look at the ACT Desktop mill. It'll hold the tight tolerances and it has a cast-iron T-slot table bigger than you're asking for. Its fast spindle is well-suited to cutting aluminum, and it comes ready to run, with a computer preloaded with Mach3. It's heavy, but 2 (fairly strong) people can still pick it up. There's info about it on my site; they also advertise here in the Zone.]
Andrew Werby
www.computersculpture.com
Old 08-20-2009, 06:35 PM
zaebis is on a distinguished road
I cant vouch for lathe, but CNC if you are looking for a new mill, Tormac, Industrial Hobbies, Novakon 200, Syl X6 those are 1200-1500 pounders that will do the job within your budget. Stay away from the desktop mills and certanly not the table tops.
Old 08-20-2009, 06:45 PM
How complicated are the parts and over what time frame are you wanting to make hundreds?
When makimg lots of parts using a program that needs several different tools a machine with a toolchanger is almost essential to keep the manufacturing time short. Also with parts that require large amounts of material to be removed a machine with a fast spindle speed, upwards of 7500 rpm and plenty of power is needed to keep the times down.
Your budget is almost at the range of buying a used full scale machine and it might be worthwhile looking into this.
Advice choosing machine please apriorius Tormach PCNC 10 11-21-2008 05:13 AM
Machine not level - Need advice studysession DIY-CNC Router Table Machines 8 08-28-2007 10:05 PM
machine advice 7602 General Metal Working Machines 4 03-18-2006 12:13 PM
Starting first machine, looking for advice. nuplowboy DIY-CNC Router Table Machines 2 01-17-2005 10:57 PM
1st Machine, need advice... Tabor DIY-CNC Router Table Machines 5 10-19-2004 04:38 AM
