Results 1 to 6 of 6
Thread: what material to use for guilotine blade.
    Aug 2009
    need some help on what material to use for a home built manual 1200mm guillotine blade. Would apprecite any ones advise on this. Cheers
    Mar 2008
    Depends upon whose head you're decapitating as some are tougher than others.
    Seriously now...is this for a paper guillotine?
    Jul 2005
    Paper guillotine?
    Long blade type or rolling wheel type?
    To some extent your steel choice depends on how much usage you anticipate. Simple medium carbon or high carbon steel would work hardened and tempered back to the point where a good file could just make a mark; you don't want it dead hard because it would be too susceptible to chipping.
    If you are getting really carried away with something that will last forever, or at least a very long time, go for High Speed Steel. Although I wonder if you can get it easily in that length; the longest I have seen was 30 inches for chipper blades. Incidentally chipper blades would make an excellent guillotine knife.
    Registered LeeWay's Avatar
    Jun 2004
    You might also look at manuals for similar machines and see if you could order replacement blades. Then all the tough decisions are already done. Design yours around the blade from the start.
    Lee
    Aug 2009
    thanks fellas. firstly its for zincaneal sheet metal up to 1.5mm for general fabrication work and will be used fairly regularly.
    it will be a long blade scissor action.
    buying a replacement blade and building a guilo around it is a great idea Leeway.
    will I need to ensure the working face that the blade shears against also be the same material as the blade?
    Mar 2008
    I get it...we call it a shear over here.
    We have many places here that make "machine knives" here, at least 3 in my county alone. They machine and grind blades for sheet metal shears, plastics processing machinery, etc.
    1. Need Help!- Circular saw blade?
      By rai in forum CNC Tooling
      Last Post: 01-29-2009, 08:36 AM
    2. Need Help!- Mini lathe parting/grooving blade or tool with blade help
      By Jaime128 in forum Mini Lathe
      Last Post: 01-02-2009, 04:55 AM
    3. Band Saw Blade TPI?
      By JWB_Machining in forum General Metalwork Discussion
      Last Post: 10-30-2008, 08:43 AM
    4. using a saw blade?
      By marktill in forum SprutCAM
      Last Post: 04-01-2008, 05:06 PM
    5. 5 Blade Fan,
      By CharlieM in forum G-Code Programing
      Last Post: 02-13-2008, 05:52 PM
