Old 08-12-2009, 02:26 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Mini CNC Rotary Table
Does anyone have a source for a 4" CNC rotary table? I've done some looking around, but they don't seem to be that common of a machine.
I'm interested in specs, since I've just finished a conversion of a LMS 4" table in a nice compact design. I would like to see what others have achieved for output RPM. I get 6 rpm, which seems to be adequate speed for running on a mini-mill. What would a $10k Haas table have for output speed?
Another question for those that have a CNC rotary table and are using mach 3. How is your A axis calibrated? Currently mine is calibrated in degrees, so the dro in mach 3 is in degrees. Is this normally how it's done? So if I want it to rotate 3 times in one minute, I use a command like G1 A1080 f1080.
Thanks,
Paul
Old 08-12-2009, 03:55 PM
beege's Avatar
beege is on a distinguished road
I have one of these:
http://www.nutec1.com/index_files/PD...RT/RT5_STD.pdf
from here:
They make an even smaller one.
Old 08-12-2009, 04:35 PM
Does your table turn at 45rpm?
Old 08-12-2009, 05:24 PM
beege's Avatar
I'm sure it would if the rest of the machine was up and running. It did before the controller died. Even faster. I have to refit with a new controller, 4 axis. Did you look at the T-Max line? Their RPMS go up to 1200, if you're looking for speed (or so they say). Give'em a call?
Old 08-13-2009, 10:56 PM
Jay C is on a distinguished road
Did you buy the Nutec new or surplus? Do you mind sharing how much it was?
Best Mini Mill for Rotary engraving nosplinters Benchtop Machines 31 08-16-2009 07:46 PM
How do you use a rotary table? ranchak General Metal Working Machines 0 01-30-2008 10:30 PM
rotary table bulletfab Haas Mills 4 12-16-2007 02:48 PM
Useful for Rotary Table? Ken Stuempge Mechanical Calculations/Engineering Design 2 02-12-2006 09:16 AM
Mini-Lathe and Rotary table retrofits JFettig Product Announcements & Manufacturer News 0 07-13-2005 07:51 PM
