Old 08-09-2009, 10:20 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Question HMC Doubts
Hi
Had plenty of doubts regarding HORIZONTAL MACHINING CENTRE -
1 : How parts are been aligned on hmc as the operator needs to fight against gravity ?
2 : Also what is that tombostone mechanism...I guess it a fixture parrallel to the machine axis.
3 : Also is that so that hmc is only been limited to parts (holded in some fixture) or cubic parts....
4 : Are dies ( just like what are been manufactured on VMC ) can be manufactured on Horizontal machining centre....
Thanks all...
Ash
Old 08-09-2009, 11:52 AM
PixMan is on a distinguished road
Originally Posted by Ashish B View Post
Hi
Answer: There is no such thing as gravity. It's just that the earth sucks. OK, just kidding. Heavy parts hanging on a sling from an overhead crane can be unwieldy, but trying to load the same on a VMC can be worse when trying to work around the spindle housing.
Answer: A tombstone is best thought of as being just the same shape as it's namesake, a tombstone. Most offer 4 surfaces perpendicular to the spindle rotation axis. Some more surfaces, some less depending upon design. They allow you to load parts on multiple surfaces. Try that on a VMC without a space-limiting rotary indexer/interpolating axis added on, further complicating loading larger parts.
Answer: Yes. Smaller parts are held in vises bolted to a tombstone, or bigger parts are fastened directly to the table. The shapes of parts you can machine on an HMC are limited only by your fixturing/mounting imagination. Every HMC I've seen has bulit-in rotary tables or pallets to afford machining operations on 3 planes (or more) in one fixturing.Try that on a VMC with just a vise on the table holding the parts.
Answer: Yes, but much easier! All your chips use that worldly sucking force (gravity) to allow the chips to fall away, out of the cavities being machined. On a VMC, you have to flush them out with coolant (flood or HP) or air.
Thanks all...
Answer: You're welcome. My pleasure.
Old 08-10-2009, 12:35 AM
Ashish B's Avatar
Smile HMC
Thanks all...
Really thankful that for that valueable info.
Had a minor doubt.....how much time it takes to align the part on a HMC as compared to VMC....???
As in HMC the operator has to fight against alignment as well as the crane whcih will hold the part...
But in VMC U need to only fight against alignment...that's it...
Ash.
Tags
hmc
OSuni-3 board doubts trebby Stepper Motors and Drives 3 01-23-2007 08:38 AM
OSuni-3 board doubts trebby Stepper Motors and Drives 0 01-18-2007 09:01 AM
Learner's Doubts sevulu CNCzone Club House 0 06-30-2005 09:18 PM
